1996 Ranger
Old Aug 18, 2024 | 07:54 PM
Nik78's Avatar
Nik78
2nd Gear
1996 Ranger
It runs until it get hot and then shuts down. And will start back in a hour or so and tun fine. Ik I need a purge evaporator valve and new coil packs. Could one of those be the cause of my issue?
Old Aug 19, 2024 | 07:54 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
Seeing as how the 96 should be OBD-2 diagnostics, scan it for pending or set trouble code clues & post All code Numbers as they can help focus a trouble-shoot.
All that said lets think about this some more, remember it takes air, fuel & spark to make em run, so when it hot stalls & won't restart which one of those 3 is missing?
I've seen something as simple as a faulty gas cap not venting the tank & causing negative pressure as fuel is used that the fuel pump can't overcome cause a fuel starvation stall, so when it lays down & won't restart, open the gas cap to equalize tank pressure & see if it'll restart, if so, replace the gas cap with the specified Ford part.
If you don't have a code reader, or scan-tool to help in the trouble-shoot, when it stalls use your fuel pressure tester at the under hood fuel rail Schrader valve test port to test fuel pressure & your timing light to check for spark.
Might be helpful to know which engine this puppy has & if this problem began slowly over time or suddenly after some event?
Some initial thoughts for consideration, let us know how it goes.
Old Aug 19, 2024 | 09:43 AM
Nik78's Avatar
Nik78
2nd Gear
Originally Posted by pawpaw
Welcome to FTE.
When it does die and you try to start it, it sounds like it isn’t getting fuel. But as I said once it sits for a spell it will start back up. That being said, I do know the purge evaporator valve does throw a code. Will take it to parts store and get them to run diagnostic on and post codes, for further details.
Old Aug 19, 2024 | 10:00 AM
BareBonesXL's Avatar
BareBonesXL
Driving around for hours until it gets hot? Or idling in the driveway until the engine warms up?
Why do you think that you need a new coil pack? The EVAP system purge valve shouldn't cause the engine to die.
Good luck at the auto parts store.
Mcopeland57
Jun 13, 2017 12:51 AM
7.3idi-fan
Feb 16, 2017 09:17 PM
IB Cristina
Newsletter Archive
Sep 29, 2015 05:40 PM
