Can Someone Explain 4x4 Switch?
Old Nov 28, 2003 | 06:58 PM
njxlt's Avatar
njxlt
Can anyone explain the 4x4 switch in my 98 Expedition? I know 2wd and 4High & 4Low do, but what happens in AWD? Does it operate with the rear wheels till there is slippage then engage? In general bad conditions where should I be driving with AWD or 4High. This is my first truck that has an all wheel drive option. Any help would be appreciated.
Old Nov 28, 2003 | 07:14 PM
tonum24's Avatar
tonum24
oops
Old Nov 28, 2003 | 08:11 PM
MisterCMK's Avatar
MisterCMK
The AWD option puts the truck into 4 wheel drive when there isn't an traction. 4high leaves the truck in 4 wheel drive all the time. It is more fuel efficient to put it in 2 wheel, but AWD is good for around town in the winter. I usually put mine in 4 high when driving in neighborhoods since it can be really slippery where I live. In bad conditions, leave it in AWD, but if you feel it constantly going into 4 wheel, just switch it over to 4 so you don't put at much wear on the transfer case.
Old Nov 29, 2003 | 06:51 AM
D2EBMA's Avatar
D2EBMA
On my 2000 EB, there is no 2WD option. There's A4WD, 4H and 4L. I understand what mistercmk is talking about - putting undue stress on the transfer case, but what other option do I have? Did Ford do anything (in general) to compensate for the inability to force the truck into 2WD?
Old Nov 29, 2003 | 10:23 AM
Iceman8984's Avatar
Iceman8984
Read A4WD VS AWD VS 4WD, that should answer all your questions. Long but very informative.
Old Dec 7, 2003 | 06:23 PM
silasgore1's Avatar
silasgore1
question...
mistercmk,
You wrote: "In bad conditions, leave it in AWD, but if you feel it constantly going into 4 wheel, just switch it over to 4 so you don't put at much wear on the transfer case."
Okay, is it supposed to go in and out of 4 wheel drive when in AWD? Is that why my dash lights keep switching from AWD to 4wd when I'm in the AWD mode?? I didn't know it switched in and out automatically?
Tim
Old Dec 7, 2003 | 10:01 PM
jasonv's Avatar
jasonv
sometimes when i have it on 4L i will get a Low Range light. can anybody tell me what that means?
Old Dec 7, 2003 | 10:24 PM
PaulC's Avatar
PaulC
The Low Range light is simply indicating that the transfwr case is in 4L. It should be on ALL the time the transfer case is in 4L.
Edlittle
Apr 6, 2014 07:17 PM
67and71_Carl
Jan 19, 2013 09:31 AM
old farmer
Apr 10, 2009 11:06 PM
camper1083
May 16, 2008 09:25 PM
njxlt
Nov 2, 2007 09:08 AM
