Parking brake issues
Old Aug 11, 2024 | 06:30 PM
jimzpsd's Avatar
jimzpsd
2017 F350.....it seems I am always adjusting the parking brake so it holds on an incline. Once adjusted, its good for about a month and then time for another slack adjustment. Its used daily and never over done. Does anyone else experience this behavior too?
Old Aug 11, 2024 | 07:12 PM
2004Limited's Avatar
2004Limited
subscribed - I only use mine if I get out of the truck, and it’s running, which is very rarely. I also always use it when connecting the trailer up, but I do not use it daily!
Old Aug 12, 2024 | 06:07 AM
senix's Avatar
senix
probably have to take one wheel down and look at it. Labor intensive to just check them though.
Why so much use? I only use mine if on the incline or if running and I feel I need it.
Old Aug 12, 2024 | 07:42 AM
jimzpsd's Avatar
jimzpsd
Being used daily consists of various trailers being pulled; hay wagons, tractors, machinery. Heavy loads in hilly terrain and I don't want to rely on the transmission pawl to hold everything. Its also a good habit to use the parking brake on a regular basis to avoid the rust from taking over, otherwise once you finally need it and use it, it may not release all the way.
Old Aug 12, 2024 | 07:46 AM
WXboy's Avatar
WXboy
Mine doesn't do that.
There's a little "star wheel" adjuster inside the rear drums. Best thing to do is remove both rear rotor/drum assemblies, run those star wheel adjusters all the way down to their shortest position, then reinstall the drums and bolt everything back up and go through the rear slots in the brake drums to adjust them. That way you can get both sides equal by turning the adjusters the same amount. Drivers side, turn the wheel downward to extend the brake shoes out. Passenger side turn it upward to adjust shoes outward.
Old Aug 12, 2024 | 08:45 AM
CBEllis's Avatar
CBEllis
I use mine daily too. But it's electric so I can hear it engage and disengage. It's a fairly quick motion but I can hear it over the motor. So far, it seems to be working good. I'm on trails and uneven ground daily - that's when I use it, opening gates, inspecting job sites - really any time that I think the grade could put the transmission in a bind, I flip on the e-brake. So far, it's holding steady every time, but I think it functions differently. Now, we have an Armada too and I/we use the e-brake the same way so as not to bind the transmission, and it feels like it needs to be adjusted/tightened.
Old Aug 16, 2024 | 08:17 AM
jimzpsd's Avatar
jimzpsd
I know the procedure, done it many times during my life. I'm asking if anyone else is make more frequent adjustments.
Old Aug 16, 2024 | 09:12 AM
6.2caribou's Avatar
6.2caribou
If it isn't being caused by a bad/fraying/separating cable(s), then the only other causes would have to be brake pads that are "disappearing" or self adjusters that are backing off...correct?
My last Ram had a similar issue. When I tore it apart I found that 2 0r 3 of the 4 pads were no longer attached to their backing plates.
mgerdau
13
Aug 20, 2023 12:11 PM
KoreanFord
15
Oct 31, 2021 09:41 PM
RJ sheedy
15
Nov 15, 2016 04:41 PM
moski
Jun 18, 2011 10:10 PM
idealtrucks
2004 - 2008 F150
Jan 17, 2010 03:09 PM
