6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Fan Clutch control parameters
Old Aug 7, 2024 | 02:20 PM
philn's Avatar
philn
Originally Posted by Steamy Lou Stool
How is your transmission fluid?
Fluid needs to be flushed. I was just about to do a complete flush + filter. It doesn’t seem burned or discolored. I’ll know more when I drop the pan when doing the filter.
Old Aug 7, 2024 | 02:34 PM
Steamy Lou Stool's Avatar
Steamy Lou Stool
Level is okay though?
Old Aug 7, 2024 | 02:58 PM
Steamy Lou Stool
What is the build date of your truck?
Also, when you drop the pan look closely for metal glitter in the fluid, and the condition of the trans filter for any obvious damage.
You can change the filter, flush the fluid, and then you can look at changing the OD Solenoid.
Old Aug 7, 2024 | 03:07 PM
philn's Avatar
philn
Build of 01/2010. Yeah, I plan to look for junk in the pan and hope to find none.
Old Aug 7, 2024 | 08:41 PM
philn's Avatar
philn
Update on temp findings after getting Forscan with pretty level driving. My truck does have ladder rack and tips the scales at just under 10K so it's heavy and dragging a sail through the air.
40 MPH or less 60-65 MPH. 70-75 MPH
Engine oil temp = 215. 231 228
Engine Coolant = 192. 195 194
Transmission = 163. 168 166
Intake air = 111 102 91
Fuel Rail. = 130 138 138
The only correlation that I can see with the fan ramping up and down is intake air temp. When it drops below 95, the fan seems to ramp down despite my oil temp being 228-230. I feel as though my delta T is a bit high with regard to oil temp. I will check tomorrow morning to see what the temp is after a cold soak. I will be doing a transmission filter change and flush followed by a coolant flush and thermostat change. I don't plan on adding any harsh flush to the coolant. I'm skeeered! I will just dump the coolant and flush with water.
Old Aug 7, 2024 | 09:15 PM
Steamy Lou Stool
Coolant Temp is perfect.
I believe the once the oil temps starts getting 220+ it starts to kick on the fan. With coolant/ oil temperature difference like you have you might want to start looking at the BPD Half-Kit, although you are fine at 230 with synthetic oil.
Transmission temp is prefect
Did you check both IAT sensors? You only have one posted.
Fuel Rail temps are fine, what’s your ambient temp?
One other thing is your AC, once you get forscan you should be able to see if the high pressure switch is kicking the fan on.
Old Aug 7, 2024 | 09:24 PM
philn's Avatar
philn
Did not check both IAT sensors. Will do that tomorrow. Ambient temps this evening were about 90. I turned the A/C off and it did not make any difference. The oil temp is my major concern at this point. I'll check the sensor tomorrow after a cold soak to see if it's off but I bet my oil cooler is just beginning to clog. I'll have to order all of the stuff to get that job done soon. Not looking forward to it. Will do with cab on but jacked up a bit in order to get to the rear turbo bolts. If I had the cash, I might pay someone to do it but I doubt anyone in our small town can, or will do it. Plus, I'd rather do it myself and know that it was done right.
Old Aug 7, 2024 | 09:28 PM
Steamy Lou Stool
Ambient temps at 90, your Fuel temp is good,
For the Oil cooler, would probably recommend the BPD Half-Kit, if your running synthetic oil you are fine running 230 oil temp. Although, it is still relatively high.
Only thing about the BPD kit is the price, last I checked was around $1500, although it saves you time vs trying to install an oil cooler cab on.
Old Aug 7, 2024 | 09:33 PM
philn's Avatar
philn
I bought the truck with 150K and it now has 300K. I've run synthetic from day one. Previous owner appeared to have Ford change oil and other fluids regularly according to maintenance schedule. I've done 2 water pumps and have flushed coolant twice more for a total of 4 flushes in 150K. I should have done more and wish I'd installed a coolant filter a long time ago.
The BPD half kit looks great. With my luck, I'd install it and the original oil cooler would rupture and have to be replaced anyway. I'd be willing to spend the $$$ if it were a permanent fix. That oil cooler changeout looks horrid though. I'll have to flush the system first to see if I gain any ground before taking on that changeout.
Old Aug 7, 2024 | 11:54 PM
Steamy Lou Stool
If you already have ELC coolant in the system, and your truck is fully deleted, I personally would just go with the Half-Kit, Your oil cooler is not really badly plugged(ie. 250 plus oil temp), still 230 is high, but the half-kit saves you a lot of time not having to pull the turbo cab-on to access the oil cooler, and whatever parts you might need when messing around with the normal oil cooler install like if you damage your up-pipes, etc.
The 6.4’s don’t rupture as many oil coolers like the 6.0’s did, and even if your oil cooler gets plugged even more, the half-kit from BPD should be able to keep your temps down no problem.
I currently have a 6.4 that averages around 220 oil temp on the highway, but I am going to get a Half-Kit soon, not worth it to me to put that much time into a normal oil cooler for it to plug up again eventually.
Old Aug 8, 2024 | 12:09 AM
Steamy Lou Stool
Did not go into reduced power. I did reset the codes after taking a snapshot and then very gingerly got back on the highway and made it home without too much trouble. The transmission is definitely not acting right. Upshift from 2-3 is rough and it does hesitate to go into final gear. The fan cycled continually for 2 hours. Ramped up to full and gradually ramped down to nothing and then 5 seconds later it repeated the cycle.
Also, if you want before you do the flush the trans and do the filter and look replacing the OD solenoid, you can relearn the Transmission I will include a picture of how to. Most likely it is either your OD solenoid is contaminated or your Overdrive Clutch is Going out, but this procedure is easy to do.
The Procedure is to disconnect both batteries, wait 5-10 minutes, do steps 2-6, then drive at around 15% throttle all the way to 6th gear, then repeat at 40%, then at 75%.
Old Aug 8, 2024 | 10:53 AM
philn's Avatar
philn
I greatly appreciate all of you help. This forum has saved me in the past due to people like you. I am glad to hear that the 6.4 doesn't have the same rupture issue as the 6.0. That will make my decision easier. This is my HVAC service truck and I don't want it down for a full week while I attempt an oil cooler changeout. I'm concerned about breaking bolts off in the turbo when trying to take off the up pipe. I don't want to create a cab off repair debacle. I'm about to pull the transmission pan. I hope it's clean.
Again, thanks for the info.
Old Aug 8, 2024 | 11:52 AM
  #28
philn's Avatar
philn
So, pulled the transmission pan and immediately heard something in the pan. Fluid looked pretty good and didn't smell burned. I drop the pan, pull out the filter and find one of the valve body bolts completely out and the one next to it about ¼" backed out! And, they are right where solenoid B is, which was one of my fault codes. Most of the bolts holding the valve body were loose. The only ones that were tight were on the part of the body towards to the rear.
saw a little bit of glitter and the magnet had what I would consider normal, very fine particles stuck to it. So, maybe my transmission issue will be solved soon.
Old Aug 8, 2024 | 05:50 PM
  #29
Steamy Lou Stool
Little particles attached to the magnet is fine, especially if the fluid or filter has not been changed in 50,000+ miles, hopefully bolting everything back up correctly will fix your shifting problem.
Old Aug 8, 2024 | 07:22 PM
  #30
philn's Avatar
philn
Everything went well on the test drive. Had to drive about 50 miles with lots of stops and starts as well as highway driving before the 2-3 upshift smoothed out. It's shifting smoothly now. I still have a hard time believing that the bolts were that loose. I had never heard of anyone having that issue before.
Fan still ramps up and down for whatever reason. My oil temps are no more than 230 degrees at speeds of 60+ and hover around 220 for just running around town. At what delta T will the PCM put me in limp mode? My coolant is running about 192 with oil at 225-230. I'm still debating whether or not to do a cab on oil cooler change or the external kit for $1600. If I can put on the external kit and drive this truck another 50k miles, it would be worth it.
