Front leaf springs
I installed a set of 3leak front leaf sprgs on my 95 f250 with 7.3L diesel. What other parts do I need to correct the front wheels from looking like the front end has wedgy = tires are canted out at the top pretty far. It raised the front end by 1-1/2inch. I plan on replacing the rear sprgs with 2in leaf set. ALso installing Bilstiens front & rear.
Lancer
Maybe a mod could move this to this appropriate forum, this forum is for 1999-2016 Super Duties.
https://www.ford-trucks.com/forums/forum28/
https://www.ford-trucks.com/forums/forum170/
In the mean time, search for Moog adjustable camber/caster eccentrics (bushings). They may get you where you need to be.
Drop brackets. Ether purchased adjustable, or fabricate a set to your requirements.
And Google, Dana 50 TTB alignment / camber issues.
and you'll need adjustable eccentrics
https://www.rockauto.com/en/moreinfo...13508&jsn=1108
