Fuel system issues continue
Old Jul 25, 2024 | 06:20 PM
rmdonaghy's Avatar
rmdonaghy
Hey all. 89 F250 7.5 L the usual dual tank issues. So... been having fueling issues for a while, front tank full but cant access it, new dual action valve, front tank works for 3 min, truck wont run at all any more, clean sand out of valve, rear tank works front does not, bypass dual valve for rear tank, front still hooked up, rear tank pumping into front tank overflowes onto road, me not happy wasting precious gas. remove valve hook up rear tank only works fine. remove front tank, full of rust, fuel pump leads corroded off. Had ordered sender and intank pump as gauge always said full anyway. drove to town to fill rear tank, switched to front just to see what it would do - remember tank is on the ground at my house, drove 20km to and from town switch on front tank, still ran fine. so switch isnt switching tanks although it swwms to be switching fuel level gauges. Front tank still shows full even though its not in the truck. What now?? Could there be an ecu issue?
Old Jul 25, 2024 | 07:03 PM
Soup bean's Avatar
Soup bean
Start with the advice in the second post of your original thread https://www.ford-trucks.com/forums/1...-problems.html.
The Dual Function Reservoir (fuel tank selector valve) works off of the hydraulic pressure, from the in tank fuel pumps.
The in tank fuel pumps need to supply proper pressure to the Dual Function Reservoir and the gasoline needs to be clean. The Dual Function Reservoir won't tolerate sand or debris.
Once you establish that both fuel pumps are delivering clean fuel, at proper pressure, to the DFR, then move to testing pressure on the return side of the DFR.
You've got to be methodical in testing this system.
Old Jul 25, 2024 | 07:13 PM
rmdonaghy's Avatar
rmdonaghy
Right now there is no DFR or front tank but if I flip the switch to the front tank it still runs. The rear fuel pump is not shutting off.
Old Jul 25, 2024 | 08:09 PM
Soup bean's Avatar
Soup bean
My guess is that fuel is being siphoned from the rear tank, then the frame mounted, in line pump is pulling from the rear tank.
I know that when you disconnect fuel lines at the DFR, fuel will siphon indefinitely.
But, that's just a guess. I don't have experience modifying these systems. I've done a fair amount of troubleshooting and installation on complete systems.
Old Jul 25, 2024 | 08:41 PM
rmdonaghy's Avatar
rmdonaghy
That's true. The high pressure pump can probably suck fuel from the rear even without the rear pump running.
Old Jul 26, 2024 | 06:21 PM
My4Fordtrucks's Avatar
My4Fordtrucks
There was no fuel pressure from the front tank to cause the valve in the DFR to switch from the rear to the front so the ports on the rear tank are still open. You will need to address the debris problem in the front tank. It only will that damage the DFR but could also make its way past the filter and into the injectors.
The rear pump not turning off is a problem. That could indicate a problem with the selector switch not turning off power to the rear pump and supplying power to the front pump.
matkinson13
21
Oct 9, 2023 08:02 PM
gg1968
Oct 24, 2020 04:49 PM
lud04X
Dec 3, 2011 09:58 PM
chrisvman
Feb 6, 2005 10:15 PM
FilmGuy
May 17, 2004 01:20 PM
