Engine Coolant Reservoir
Old Nov 28, 2003 | 08:53 AM
BigMacZack's Avatar
BigMacZack
Greetings,
I have a '93 Ranger, XLT model, w/a V6 3.0. Here is the problem. I bought it used a few months ago and everything was fine then. (as is usually the case) Actually, there were no problems until about two weeks ago. I noticed that the needle on the temperature gauge started running high, as high as 3/4ths and sometimes higher. It had never gone past halfway before, so when I reached my destination, I parked the truck and opened the hood. There was coolant spewing forth from the upper top corner of the radiator. It literally looked like Old Faithful. Since my truck has 168,000 miles on it, I figured that I would make an investment and get a brand new radiator.
After getting the new radiator, everything was fine, and still is, except for one little thing. I noticed after driving for about a half-hour, that the coolant level in the reservoir, had dropped down to about two-thirds. After another day or so of a regular amount of driving, the coolant level now only has about a level about a 1/4 of an inch deep.
I checked the radiator itself, (after it cooled down of course!) and the coolant level is fine. I've checked for leaks on all the hoses, around the top and bottom of the radiator, and also around the coolant reservoir. There is no sign of fluid anywhere and I'm not sure if that's a good thing or a bad thing. Also, when I check under the truck after letting it sit for a while or overnight, there is no evidence at all of a leak. Does anyone have any idea what could be happeing? Thanks.
Old Nov 28, 2003 | 09:32 AM
emtabmm's Avatar
emtabmm
When truck is COLD, remove radiator cap and start engine, look for bubbles..... possible failed headgaskets, and I hope you installed a new thermostat, old one would be cooked....
Old Nov 28, 2003 | 10:27 AM
seagull369's Avatar
seagull369
As long as the level in your radiator is fine over the long haul, I dont think there is any need to worry about varying levels in the reserviour. The level in the reservior is dependent upon how hot the coolant temperature in general gets. The hotter the coolant gets, the more it expands, thus the more that will spill over into the reserviour.
Old Nov 28, 2003 | 10:41 AM
emtabmm's Avatar
emtabmm
Fluctuating is ok, steadily dropping is not...
Old Nov 28, 2003 | 11:15 PM
racsan's Avatar
racsan
have you checked the oil level? if it is going up chances are your coolant is getting into the crankcase, if not a head gasket, you may want to check the intake gasket, ive never had a ford v-6 apart , but i had a astro (gm) with a leaking intake gasket on a v-6.
billbot
Jul 9, 2013 01:12 AM
kxfjerry
May 10, 2013 09:22 PM
donandbj
Nov 23, 2010 02:31 PM
samdog
Modular V10 (6.8l)
Jul 5, 2006 12:02 PM
RisingR
28
Sep 13, 2004 09:14 PM
