ABS dashboard light/speedometer?????
Old Nov 28, 2003 | 02:06 AM
Ranger802's Avatar
Ranger802
Question ABS dashboard light/speedometer?????
I've got a '99 F250 Superduty 2WD with 55K miles on it. When the truck hit apprx. 50K, the ABS light went on and has stayed on every since. I checked the brakes and the pads are not worn, nor do the discs show any wear out of the ordinary. I haven't towed anything with this truck since it had 20K on it. Is this a warning light to have the brakes serviced? Recently I have also noticed the speedometer doesn't engage until hit 30 MPH. Is this some kind of computer problem as well? If not how can these problems be corrected? Help please...
Old Nov 28, 2003 | 08:03 AM
emtabmm's Avatar
emtabmm
You have a sensor in the abs system failing, the sensor on the rear also provides info for the speedo....
Old Nov 28, 2003 | 09:46 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The VSS sensor on the top of the rear diff housing is bad. It's about $15 at the dealer, very easy to replace.
