AC issue
Old Jul 18, 2024 | 09:48 PM
Texasbred's Avatar
Texasbred
4th Gear
AC issue
Pulled a vacuum and it was holding at -30. No leaks. Pressure low side is 45. Compressor runs. It’s not cooling. I replaced the high and low switches.
Old Jul 19, 2024 | 07:10 AM
projectSHO89's Avatar
projectSHO89
Insufficient information provided.
It would help if you identified what you're working on as well as the state of charge and both gauge readings.
Old Jul 19, 2024 | 12:11 PM
Texasbred's Avatar
Texasbred
4th Gear
Yes it would
2004 f150 5.4 used a friends vac pump and gauges. And used his gauges to install Freon. So I don’t have access to the high side now.
Old Jul 19, 2024 | 04:07 PM
RLXXI's Avatar
RLXXI
Not enough info to take any diag steps. MUST have both high and low side readings as stated previously.
Old Jul 19, 2024 | 07:53 PM
Texasbred's Avatar
Texasbred
4th Gear
Ok. Thanks. Makes sense.
Old Jul 19, 2024 | 07:56 PM
Texasbred's Avatar
Texasbred
4th Gear
Proper tools better response. I get it. I don’t have access to a set of gauges, now unfortunately. Probably ought to pick up a set. Cheaper than a service call.
Shawnc74361
Jul 1, 2024 06:11 PM
bajaphile
Apr 21, 2024 11:32 PM
Drenalin
57
Jun 23, 2023 05:39 AM
tjc transport
May 30, 2022 08:20 AM
carl2591
18
Aug 24, 2017 07:02 PM
