proportioning valve
Old Nov 28, 2003 | 12:51 AM
badass truck's Avatar
badass truck
proportioning valve
well guys i had some unfortunate luck. i went to take the brake line for my front passenger side off the propotioning valve and the line broke right behind the fitting and my brother swept up my garage and threw it away. now i can't find a new fitting. i can't bend the new brake line with a sharp enough anle to make the turn since it goes in right near the frame. so i need a 90 degre angle. but i can't find one any where for the proprtion valve. you guys got any suggestions?
thanks ahead of time
Old Nov 28, 2003 | 06:32 AM
tellico racing's Avatar
tellico racing
Re: proportioning valve
Try using a tubing bender and make your own. Or adjust the location of the proportioning valve so you can get a line on it.
Old Nov 28, 2003 | 12:19 PM
badass truck
ok, i 'll try adjusting the valve so i can get the line on, i can't bend the line enough as it is to get it on cause the angle is to sharp
