Vacuum question
Old Jul 16, 2024 | 10:10 PM
kenny nunez's Avatar
kenny nunez
Question Vacuum question
Where does the vacuum enter the interior to feed the ac controls? I recently started working on this truck and I think someone really messed this thing up.
I removed the vacuum manifold from the rear of the control, there is no vacuum to the black hose. The check valve has been replaced with a “T” fitting and I am getting the correct check valve tomorrow.
Hopefully someone has section 12 -page 00 & 03 of the manual.
I have the Ford electrical & vacuum manual but no service manual.
1994 F150 XLT 5.0
Old Jul 17, 2024 | 12:55 AM
Junktownbill99's Avatar
Junktownbill99
I believe HVAC vacuum runs through the firewall passenger side.
Old Jul 17, 2024 | 07:22 AM
manicmechanic007's Avatar
manicmechanic007
Correct
You should see the little black vacuum tube go through the firewall somewhere near where the A/C hoses go through
The one way valve that the hose is attached to needs to be checked
That tees over to the intake vacuum tree
Check your underhood VECI (vacuum diagram)
Old Jul 17, 2024 | 09:02 AM
kenny nunez
Question Vacuum line
The check valve is good. One side is connected to the vacuum source from the vacuum tree, the other goes to the actuator blend door and the other one goes to a panel under the insulation which I removed only to find it dead ending with a very small metered orifice.
I removed the right kick panel and traced a black & white hose going up with wires going through a metal panel that I thought went into the cowl duct panel. It does not.
Many thanks for the response.
Old Jul 17, 2024 | 04:42 PM
kenny nunez
Smile Vacuum supply
I finally found it! It was on the bottom of the harness barely sticking out coming out of the plenum. It has been broken probably for the last 15 or so years.
I have been working on this thing for the last 6 months bringing it back to life and saving it from a visit to the crusher.
It now should have another 10 years of service left in it.
1994 F 150 XLT 5.8 with extended cab. It was originally a 5.0 mass air but a rebuildable 5.8 is now running in it with the mass air.
Excurvelle
Jan 29, 2026 08:15 PM
Junktownbill99
Jan 13, 2023 02:20 PM
pecanguy
Aug 18, 2013 08:36 PM
LARIAT 85
Nov 6, 2010 04:08 PM
ladiabla74
1997 - 2003 F150
Jul 30, 2008 09:03 PM
