Van won't move
Old Jul 14, 2024 | 04:41 PM
RVweenie's Avatar
RVweenie
4wd Low
Van won't move
I have a 2008 E-150. A day ago, the left rear brake locked up in my driveway. I got that freed up so I could get it in my garage, but now the van won't move in reverse. It seems to move a bit in drive, but it is only inches from the garage wall. What should I be looking for?
Old Jul 15, 2024 | 06:07 AM
manicmechanic007's Avatar
manicmechanic007
Stuck E brake shoes
Remove the rear rotors and check the shoes inside the drums
They come apart and lock up
Old Jul 15, 2024 | 09:02 AM
RVweenie's Avatar
RVweenie
4wd Low
I fixed the brakes, but now it won't move in reverse, or in neutral, although it will in drive. The back-up lights work in reverse.
Old Jul 15, 2024 | 09:09 AM
tabijan's Avatar
tabijan
Chock front wheels, lift rear axle, put transmission in neutral. Can you spin the rear wheels? If not, are the park brake cables in tension? Is either wheel absolutely frozen or can you wiggle it a little?
Sixto
07 E350 5.4 198K miles
PStruwing
May 9, 2012 08:26 AM
IDIDieselJohn
Mar 2, 2012 05:08 AM
BigLoo
Aerostar
Nov 14, 2011 07:21 PM
fordnut78
Oct 7, 2010 09:12 PM
Skandocious
26
Oct 23, 2007 10:34 PM
