Class 8 hitch bolts?
Old Jul 9, 2024 | 09:38 PM
wpg_250's Avatar
wpg_250
I'm going to be upgrading my tow hitch to a CURT 15810 Class 5 and I want to replace the rusted stock bolts with the much better class 8 bolts, but can't find any via google so far so just curious if anyone knows where to order them from?
Thanks a bunch
Old Jul 10, 2024 | 06:40 AM
Bugzilla46310's Avatar
Bugzilla46310
Fastenal, maybe Grainger, any Ace Hardware or True Value.
Old Jul 10, 2024 | 08:04 AM
WE3ZS's Avatar
WE3ZS
You want Grade 8 hardware, not class 8. Try searching again with that term.
Old Jul 10, 2024 | 08:24 AM
Bugzilla46310
Good catch!
Old Jul 10, 2024 | 08:37 AM
Strider250's Avatar
Strider250
Thanks a bunch
Check out https://boltdepot.com/Hex_bolts_Grad...l_plain_finish
Old Jul 10, 2024 | 10:56 AM
Antonm23's Avatar
Antonm23
I went to go into Fastenal the other day but the doors were locked and big sign saying "Will Call only". So I called up the next closest Fastenal store to see if they were the same and they told me that all Fastenal's went to Will Call only, with no open showroom for walk-in customers, and you had to have a commercial account to place a will call order.
But the employee on the phone was nice enough to recommend another fastener store in the city that you could still walk into.
Old Jul 10, 2024 | 10:58 AM
Antonm23's Avatar
Antonm23
Class is also a term used for fastener strength on the metric side. A class 10.9 metric is pretty much the equivalent of an SAE grade 8.
Old Jul 10, 2024 | 09:19 PM
meborder's Avatar
meborder
that’s interesting. Our fastenal is still open for walk in. Different part of the country, granted.
Their webpage is usually pretty good if you know the size and you can just order what you need.
That said, Grade 8 hardware is nothing special to find so anywhere that sells hardware should do.
I’d look up the torque specs for the grade 8 hardware and use those values rather than what was given in the instructions. If you use the torque specs for the grade 5 hardware, then there is no benefit to upgrading IMO. Bolted connections don’t work the way most people assume they work. So the upgraded hardware could potentially be of a benefit, but only if properly implemented with appropriate clamping loads.
Old Jul 12, 2024 | 09:34 PM
Truck Fun's Avatar
Truck Fun
Some sources don't sell individual bolts/washers/nuts; meaning you buy an entire bag of each. I suggest a good hardware store or a farm supply store where you can buy only the number you need of each. Plus you may have the option of getting a couple extra of each and returning the unused pieces.
Old Jul 13, 2024 | 06:12 AM
senix's Avatar
senix
what about Tractor Supply? My local one carries individual blots, washers, nuts by the pound.
Old Jul 13, 2024 | 07:15 AM
Desert Don's Avatar
Desert Don
Tractor Supply for the win! Or maybe a local farm and ranch supply store. TSC is the nation wide store that sells by the pound.
Old Jul 22, 2024 | 04:11 PM
FuzzFace2's Avatar
FuzzFace2
A little late but https://www.mcmaster.com/
Has a lot more than just nuts, bolts & washers but like what was said may need to buy a box of.
Dave ----
Old Jul 22, 2024 | 04:22 PM
charlie g's Avatar
charlie g
FTE Community Team
take a old bolt to match to the nearest tractor supply, they sell nuts and bolts in grades 3-5 and 8 by the POUND 1/4 inch up to 1 inch thread sizes
Old Aug 2, 2024 | 12:05 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Thanks a bunch
Ummmm . . . sorry I'm late to the party, but:
. . . from: https://www.curtmfg.com/part/15810
Not just grade-8, but "strong grade-8". Not sure if the other sources specify that their grade-8 hardware is strong or not.
Old Aug 2, 2024 | 12:45 PM
senix's Avatar
senix
better than weak grade 8 bolts, lol.
I think it is word play to make it more appealing.
