My new to me 02 Excursion 7.3 Diesel 4x4 is in need of rear shocks. I would swear that they are the original looking at them.
It currently has Monroe Reflex struts in front. Should I put Monroe Reflex struts in the rear and call it a day? I don't know how new/old the fronts are either.
I have never towed anything heavy but would like the flexibility to do so in case I need to. I would like a shock that is great on road trips as well and for what it is worth helps the vehicle be the most stable on the highway even at the expense of harshness.
Thanks for any advice.
Reason: Removed color tag artifacts from post content being copied over from another sub-forum, to render post readable in Dark Mode.
Bilstein 4600 or 5100s are the go-to for most people, though be aware you will need adapters to run the 'race style' double-eyelet style shocks. Stock has the 't' bar fitting.
You will either have to extract the 't' fitting from the rear upper mount to install them, or buy adapter brackets that will allow the double-eyelet style shock. You will see when you take a look - it won't bolt right in. I chose to get the adapters so that I could install an actual bolt in the upper eyelet and use upgraded hardware for the mounting bracket also. I didn't like the feeling of those two little bolts holding the entire shock in place when towing a 10K camper.
These are the ones I went with. Also works with the 5100s - so no problem with fitment or shock travel as you will give up a little from the thickness of the bracket.
@2002 Limited...Is it hard to extract them? Also, I read to have an extra set of nuts or bolts ready because things break? Do you or anyone else know where to get these? Seems like a possible pain in the neck.
I am a bit annoyed that these units aren't truly plug and play although they are advertised as such.
I am considering the brackets that you mentioned but I am scared that they won't make it in time.
When you get the old shock off, all you need to do is pull the 't' fitting out of the upper mount. It should come out of the old eyelet. Then with some persuasion you can slide it into the rubber eyelet on the top of the new shock. I personally have never re-used shock mounting bolts, though not because I've ever had one break, just on principle. Either way, use lock tite on the mounting bolts when they go back in. I'm not sure if there is a difference in the eyelet size between the stock and new shock which would necessitate getting the adapter (the old 't' fitting won't work in the new shock, for example). Apparently there is enough of a market to produce the adapter that they do it I guess. What kind of time crunch are you under?
Thanks for all of this. Time crunch would be this Friday. The Bilsteins will be arriving then. I am also unsure as to whether or not the stock "T" fitting will fit. The answer might be somewhere in this forum but I have not found anything that popped out at me yet.
my '02 Excursion shocks have have the label "Reflex" on them, no other info.
don't know what brand they are, a diesel shop installed them 2 years ago...
did a search and now know they are the Monroe brand.
Reflex Monotube Shock Absorbers
Specifically engineered to provide better handling, control and performance for light trucks and SUVs, Monroe Reflex monotube shocks feature a high-pressure gas to provide additional spring rate, helping to maximize damping efficiency and control.
I will say this, they are HARD AS A ROCK, those speed bumps in Parking Lots?
Avoid them at all costs, they will ruin your vertebrae.
Upside, I have towed 2 tractors, and a car and a Cargo Trailer loaded to 7000 lbs, without a Swaybar installed on the trailers from Price, Utah to Tulsa, Oklahoma without incident.
it never swerved, left or right. Stable as a rock.
side note:
tires are Michelin 285/75R/16 LTX Defender street treads.
I hate the noise from AT tires, still have them, but they are stored.
