351C Regulator Wiring
Old Jul 3, 2024 | 11:22 AM
Lucy's56's Avatar
Lucy's56
1st Gear
How do you wire the regulator for a 351C engine in my 56? Don't see a wiring diagram that clearly shows other than the old 56 stock unit.
Old Jul 3, 2024 | 11:30 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
What charging system style have you gone with? Are we talking type A or B?
Old Jul 3, 2024 | 11:39 AM
52 Merc's Avatar
52 Merc
It depends on what alternator you're using, and whether it's internally or externally regulated. If you're using a conventional Ford alternator from the time period of your engine, which would be externally regulated, you can get a diagram from a 70 Mustang and it will tell you what you need to know.
Old Jul 3, 2024 | 03:28 PM
hooler1's Avatar
hooler1
Could you post a picture of your alternator and voltage regulator? We might be able to help you from there.
Old Jul 4, 2024 | 08:39 AM
hooler1's Avatar
hooler1
If the alternator and voltage regulator is like the one pictured in that beautiful engine bay above it's a matter of running jumper wires (making a nice wiring harness) between the Voltage Regulator and the Alternator. There will be four connections on the Alternator. The Battery connection uses at least a 10 gauge wire which runs back to the + battery side of your starter relay. On its way there you splice in a wire that connects to the A connection (terminal) on your Voltage Regulator. Some will also fuse the connection between the voltage regulator and the starter relay. (Fuse size depending on your wire size and the max current output of your Alternator. It's not a bad idea.)
Next you run a wire between the "F" or Field connections on your Voltage Regulator and Alternator. Then run another wire between the S or Stator connections between the two units. If you use an electric choke, on a Motorcraft carburetor you could connect it there at your Voltage Regulator "S" terminal. Then a ground wire should be ran between the ground stud on your Alternator and the mounting flange on your Voltage Regulator. Now there is only 1 connection left and that is your "I" terminal on your Voltage Regulator. It needs to run to the switched, 12 volt power side of your Ignition switch. So it has 12 volts when the Ignition Switch is in the ON position. Just like your coil would have, but don't physically connect it to the coil (if an original points style system your coil is connected through a ballast resistor and if you connect right to the coil while the engine is running the voltage is lower at that point. If you do have a ballast resistor you could connect it to the power side of it from the ignition switch, just don't use the coil connection side of that resistor.) If you don't have the 12 volts at the "I" terminal, your Alternator will not charge. Originally that "I" wire ran through a resistor that shorted across an ALT light in the dash. The resistor allowed current to pass through in case the ALT light burned out, still giving you the 12 volt signal to the Voltage Regulator "I" terminal.
I always talk grounds too in these discussions because they get overlooked. Make sure your - battery ground runs right to your engine block. From that point also run a ground cable from the engine block to the frame, and another ground from the engine block to your firewall. With all the rubber in your cab and engine mounts, electric current needs a path back to your battery. Your engine block is a great ground reference point since it needs all that battery current while cranking.
Hope this all helps!
Old Jul 4, 2024 | 10:07 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I believe this shows what Hooler is describing
Old Jul 4, 2024 | 11:51 AM
bmoran4's Avatar
bmoran4
All of this advice is heavily based on assumptions of what types of charging system equipment is being used.
Let @Lucy's56 chime back in with their specifics and we can go from there.
Old Jul 4, 2024 | 12:07 PM
hooler1's Avatar
hooler1
Thank You Ross!
I should of just posted a diagram when replying but decided to just write it out. I got too much time on my hands! 😄
saauvenshine
Nov 23, 2014 01:11 PM
polarisman729
Jul 7, 2009 06:33 PM
vliposky
Nov 19, 2005 03:44 PM
