temp
Old Jul 1, 2024 | 07:39 PM
CB3's Avatar
CB3
temp
My 1978 F-100, 302, automatic, has a 180 degree thermostat. After the engine warms up and is running the temp gauge always reads a steady 210 degrees.
Is this wrong, or what it should be?
Thanks, CB3
Old Jul 1, 2024 | 09:41 PM
Christmas's Avatar
Christmas
Thanks, CB3
The lower number on a T-stat does not mean it will run cooler. That is the opposite of what happens. With a 180 you will have an open circuit that never has time to cool. Try running a 190-195 and see if it stabilizes.
Old Jul 2, 2024 | 06:45 AM
jflem's Avatar
jflem
I think you need to check the actual temperature with a Infared temp gun to be sure of where you actually are. 210 is too high for a normal range. Also check your fan blade and shroud and how clean your radiator is.
Old Jul 2, 2024 | 07:16 PM
CB3's Avatar
CB3
Fan shroud is in place - radiator is clean - fan clutch and fan blades appear ok.
I will find an infrared heat gun tomorrow and check the coolant temp.
Thanks.
Rambo76
Dec 9, 2012 05:11 PM
86F150302
Feb 16, 2008 05:01 PM
JDSTONE
16
Dec 17, 2003 07:56 PM
RCsanjose
Jul 23, 2003 11:20 AM
m3810
1997 - 2003 F150
Aug 19, 2002 04:28 PM
