OBD1 code 212
Old Jun 30, 2024 | 10:21 AM
NICKSAN's Avatar
NICKSAN
OBD1 code 212
1994, club wagon, 5.8, E4OD
Washed van yesterday, drove for about 10 minutes, stumbled, shut off and would not restart. This has happened a few times before after washing or rain, let it sit overnight and it restarts..........
Not this time.
Crank, No start. All electrical is working fine. Except I many have killed the battery by over cranking Hooked up my jumper and still, Crank, no start.
Getting code 212. " Loss of ignition diagnostic monitor signal, Spout circuit grounded "
Pulled spout and there may have been moisture inside the connector but it may also be old dielectric grease.
Question, Could code 212 mean bad ICM, PIP sensor in Distributor, or bad ECU ?
I am in the process of replacing the ICM since I have a new one on hand.
My next step is to get into the distributor and see if there are signs of moisture,
but the distributor is way under alot of things and it looks like it would be difficult for water to get there.
Thanks.
Old Jun 30, 2024 | 12:52 PM
NICKSAN's Avatar
NICKSAN
Quick update:
After replacing the ICM It started up.
I inspected spout plug and all ECM plug and wiring (as much as I could)
I think I killed the ICM by cranking a huge amount of times and for long periods, trying to get it to start.
(The van was stalled in a bad place and i was in a bit of a panic)
It doesnt rain much here at all, last major rain I put a tarp over the hood and windshield.
I am still not sure what could be getting wet and cause this crank no start situation then when it sits overnight it starts,
I have read multiple threads about the same mid 90s econolines having the same issue.
Unfortunatley my favorite battery charger died while charging , Its an old schauer (thats in new condition), I should be able to fix it though.
Old Jun 30, 2024 | 04:40 PM
tabijan's Avatar
tabijan
For grins, observe the engine running in the dark. If there’s a lighting show, maybe secondary cables are worn and arcing, worse when it’s wet or humid, and in need of replacement. Maybe the coil is compromised.
Someone can comment whether it’s safe for you to spritz a mist over the engine to simulate rain and humidity. It’s ordinarily safe but I don’t want arcing wires to jump at you.
One hypothesis is arcing causes the ICM to overheat. Is it attached to clean metal for heat transfer?
Recalling our ‘93 5.8, you might need to run it without the air cleaner and intake snorkels to see the distributor and wires.
Sixto
07 E350 5.4 198K miles
Old Jul 1, 2024 | 03:50 AM
manicmechanic007's Avatar
manicmechanic007
Your ignition module is black in color right?
The grey ones do not have the IDM circuit and cause a code 212 on 1992-1997 models with OBD1
Old Jul 1, 2024 | 08:34 AM
NICKSAN's Avatar
NICKSAN
Sixto
Its been like this since I got it, I cant even go through car wash, it has a hard time starting after. I just forgot to not drench it LOL.
The ICM has a very large heatsink it sits in and has good air flow around. Im pretty sure it failed due to my cranking over and over and for a long time.
Thanks
Old Jul 1, 2024 | 08:35 AM
NICKSAN's Avatar
NICKSAN
Yes, its black. Ive replaced it before.
Thanks.
Old Jul 2, 2024 | 03:49 AM
manicmechanic007
I do not see those fender mounted ICMs fail much at all
I sure would be looking at the capacitors in your processor for the stumbling problem
Old Jul 2, 2024 | 05:05 AM
maples01's Avatar
maples01
If its never been open I guarantee the capacitors are shot!
Old Jul 2, 2024 | 08:03 AM
Mike1's Avatar
Mike1
Has all the indications of a cracked distributer cap. Runs alright until it's damp or wet, then won't restart until the next day. I've had that happen a few times, we used to spray the cap and wires with WD40 to get them to start, just because we were always broke as kids and couldn't afford new cap and wires...LOL
Old Jul 2, 2024 | 08:11 AM
NICKSAN's Avatar
NICKSAN
I Replaced one years ago and that fixed the problem back then. This is a separate issue.
Thanks.
I replaced one years ago, in my case only one capacitor was bad and that solved the problem back then,
That was a separate issue. Like I posted above, Im sure I ruined the ICM by over cranking and for too long.
This particular crank no start issue has been resolved by replacing the ICM on Sunday morning.
Thanks.
Old Jul 2, 2024 | 05:43 PM
maples01's Avatar
maples01
I had a friend with this exact issue, his turned out to be a remote start that a previous owner added, I can't tell you how many times it had been to the shop, I think they replaced everything on his distributor, but it was always when it was damp out.
Old Jul 2, 2024 | 07:36 PM
NICKSAN's Avatar
NICKSAN
Unfortunately its not that easy, I wish it were .
Its been doing this for years and with several different caps. I dont know where water would be getting in, but Its not much of a problem unless I forget to not flood the hood when washing or forget to put a tarp over the hood when it rains, it barely rains here at all so thats not a big deal.
Thanks.
Old Jul 2, 2024 | 11:02 PM
tabijan's Avatar
tabijan
Have you checked the corp drains? Maybe the cowl is overflowing onto the ICM or some critical module.
Sixto
Old Jul 7, 2024 | 08:25 PM
NICKSAN's Avatar
NICKSAN
Sixto
Where are the corp drains?
Today I installed a new air filter and oil breather, cleaned up the hood seals and the whole area under the hood where water could get in. Curiously right where the ECM plug is there is a large section of plastic missing and water can easily flow right over the ECM wireing. I moved one of the seals to protect the wireing and I wrapped this stuff called rescue tape over the ECM plug and wireing to protect it. I am going to fabricate a cover or barrier to protect the ECM wireng.
I dont think water can get to the ICM but I am going to wrap the connector next time I do some work under the hood. I also degreased as much of the engine as I could, next weekend I will do some more. It was around 90 degrees while working on the van.
Old Jul 7, 2024 | 09:47 PM
tabijan's Avatar
tabijan
Sorry, cowl drains. There should be one on either end of the cowl running down ahead of the door hinges.
Sixto
