ISO Correct clutch kit
Old Jun 28, 2024 | 06:00 AM
Kcooper96's Avatar
Kcooper96
Trailering
I have an 88 f150, manual 4 speed with overdrive, when I'm selecting a clutch kit on rock auto do I need a 5 speed clutch kit or 4 speed clutch kit? I've heard that the overdrive is technically a 5th gear so I am unsure which one I need.
Old Jun 28, 2024 | 06:54 AM
Mudsport96's Avatar
Mudsport96
A picture of the door tag with the transmission code would be a help so we know which transmission you have.
Old Jun 28, 2024 | 09:08 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I agree. I did not think the overdrive 4 speed was available that year. I thought that ended in the previous generation of trucks.
Old Jun 28, 2024 | 11:16 AM
TobyB's Avatar
TobyB
If it's a separate overdrive, (A-A, Gearvendors, etc)
you'll need a 4- speed application clutch.
I don't know about the T18, but the M5 and ZF5 both have tags on the boxes that tell you what they are.
t
Old Jun 28, 2024 | 03:41 PM
Scndsin's Avatar
Scndsin
T18 manufactured to 91. Installed till...?
https://www.novak-adapt.com/knowledg...manual/t18-t19
Old Jul 17, 2024 | 05:54 AM
Kcooper96's Avatar
Kcooper96
Trailering
Old Jul 17, 2024 | 08:04 AM
My4Fordtrucks
Double post
Old Jul 17, 2024 | 08:09 AM
My4Fordtrucks
Every forward gear is counted.
Transmission code “M” is the 5 speed Mazda M5OD-R2.
Old Jul 17, 2024 | 09:03 AM
Mudsport96's Avatar
Mudsport96
Th
This will work for you. I would also recommend a new flywheel. I put this kit in my 95 and it works great
señorEddie
Dec 17, 2015 09:26 AM
bearhugger
Apr 28, 2011 10:15 PM
Scratcher
Apr 16, 2011 10:00 PM
jpdunbar
Aug 22, 2006 07:38 AM
Chumbucket
Apr 5, 2006 06:30 AM
