Aftermarket diff covers
Old Jun 27, 2024 | 05:36 PM
fmuguira's Avatar
fmuguira
Anyone running an after market front diff cover on their f350? I just changed my gear lube and did an inspection of rear end so put a cover on that has an external drain. I realize the stock rear cover has a bolt you can pull to drain it but went ahead with a Ford Performsnce cover.
I now need to tackle the front diff which does NOT have a drain plug so looking at a Yukon or ARB cover and wanting to see if anyone has done one? If so, is your steering, tierods, etc all clearing? Which would you recommend? Most all the ones with a drain plug use a magnet so that’s good.
Thx for experiences/input.
Old Jun 27, 2024 | 06:00 PM
Dented's Avatar
Dented
Very interested to see where this goes. Is like to upgrade both covers to something far more robust.
Old Jun 27, 2024 | 06:59 PM
satxuser's Avatar
satxuser
I have these installed front and back. FYI: The G2 front cover did not accommodate the dual steering stabilizer mounting bracket that bolted to the stock cover.
https://www.g2axle.com/pages/view/hammer
Old Jun 27, 2024 | 07:18 PM
fmuguira's Avatar
fmuguira
So you just ordered a Dana 60 cover, not any specification, difference on Dana 60 front ….?
Lastly I m assuming it clears your stock steering setup? ( without dual stabilizer) Your truck a F350 or F250?
Thx much for info!!
Old Jun 27, 2024 | 07:42 PM
satxuser's Avatar
satxuser
Thx much for info!!
Yes, Dana 60 for my front. Stock stabilizer is fine, and is not an issue.
I have the Ford 10.5 rear differential.
Mine is an F-350 ……
Old Jun 27, 2024 | 10:06 PM
fmuguira's Avatar
fmuguira
Great, thx for input. I be got the 275 in the rear and D60 front. ( I noticed the steering linkage and Panhard bar in front are fairly close to diff cover where it sticks out to clear ring gear)
Install was simple? No removing of anything except old cover I assume?
Old Jun 27, 2024 | 10:11 PM
cnote72's Avatar
cnote72
Do you have a link for the Ford Performance cover? Like to see what it looks like.
Old Jun 27, 2024 | 10:32 PM
fmuguira's Avatar
fmuguira
I have ford performance rear 14 bolt cover (275) but I couldn’t see where they offer a d60 cover… if so I d lean that way just cause they d match. Most all the aftermarket’s are similar in design/price.
72cougarxr7
May 3, 2025 08:43 AM
GM in a Ford
Apr 6, 2021 05:50 PM
queen of spades
Mar 31, 2019 06:40 AM
patrickke
Jul 22, 2010 06:18 AM
WilliamD1979
May 8, 2004 12:07 PM
