O2 sensor question
Old Jun 22, 2024 | 05:59 PM
Eminem1111111111111's Avatar
Eminem1111111111111
O2 sensor question
I’m installing long tube headers on my 94 f150 5.8. The headers I’m putting in need to have an O2 sensor bung welded in. My question is would I be good to keep the 1 O2 sensor and weld it into the collector valve on my passenger side header, or do I need to weld it into the crossover part of my h pipe? Or do I need a whole other O2 sensor for the other side? I’ve heard different answers, that’s why I ask
Old Jun 22, 2024 | 07:07 PM
Conanski's Avatar
Conanski
In the passenger side collector works great, I verified this with testing when first installing longtubes on my '90. The reason this works is because there is only 1 fuel map for the whole engine and injectors are fired in batches which span left and right engine banks so as long as the sensor is sealed inside the exhaust it doesn't matter how many cylinders it is exposed to.
Old Jun 22, 2024 | 08:00 PM
Eminem1111111111111
Okay, sweet. My original plan was to do just the passenger, but then I heard about engines needing all 8 to be read. But now I just stick to my original, thanks
Old Jun 22, 2024 | 08:36 PM
wwhite's Avatar
wwhite
My pacesetter long tubes, could not put O2 in passenger side because too close to E4OD. The bungs for O2 already there.
Speed density, works fine with O2 only in one side, for me it was drivers side.
my future plan is to have a cross over tube like stock, don’t have true duals, driver side header curves over to passenger side, like stock y-pipe
Old Jun 22, 2024 | 11:52 PM
Conanski's Avatar
Conanski
I has that problem wth a set of Flowtech lomgtubes, the sensor would clear the transmission(AOD in this case) but not the trans cooler lines which were also there, so I had to weld in another bung on the outter side of the collector. I avoided that problem afterwords by simply buying non EFI headers and putting the O2 and EGR bungs in myself.
loseboltssinkships
15
Jun 29, 2025 11:18 AM
1986stepsidef150
Aug 3, 2013 11:17 AM
lamenytro
Jan 23, 2011 02:13 PM
Carson1219
Sep 4, 2007 12:46 PM
Crazyromi
1978 - 1996 Big Bronco
Oct 2, 2003 06:44 AM
