L&L mounts
Old Jun 22, 2024 | 11:58 AM
tlien's Avatar
tlien
L&L mounts
I’m going to be needed a new set of mounts for my 300 for my 79 f150 2wd as well as a set of engine perches/stands. Has anyone used these before? If so did you have to drill new holes for everything to line up?
Old Jun 22, 2024 | 12:25 PM
Pickupmanx2's Avatar
Pickupmanx2
What engine is/was in your truck? IIRC from the swaps I've done on 2wds, all you have to do is move the existing perches forward, towards the radiator, the holes are already in the frame, you just have to clean the crud off to find them. Unless you don't have the engine perches would be the only reason to buy new ones, or if yours are broken..
Old Jun 22, 2024 | 12:39 PM
tlien's Avatar
tlien
Mine are for a 302 and won’t work, they are damaged and I don’t think the are compatible anyway. I have the holes located but I didn’t know if these would use those holes.
winginit
Jun 21, 2016 12:18 AM
keisha9
May 20, 2016 08:49 AM
ROBBINthaHOOD
Sep 19, 2012 03:42 AM
AKFord
May 19, 2002 11:33 AM
