Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F-600 crew cab vin decoding help
Old Jun 21, 2024 | 01:23 PM
Djdjd12345's Avatar
Djdjd12345
2nd Gear
Would somebody be able to help decode my vin #F61ECN80919 it is a F-600 crew cab and was told the year was a 1969 but I am unsure of the exact year.
Old Jun 21, 2024 | 01:40 PM
Jim_K's Avatar
Jim_K
It's not a '66, that's for sure!
'69 looks to be about right, and for a '69 pickup, here's what you would use:
https://www.fordification.com/tech/VIN69.htm
Not sure if you can use this to decode an F-600 tag.
Old Jun 21, 2024 | 07:28 PM
85e150's Avatar
85e150
Thread moved to Large Truck.
Welcome to FTE! This is the place for an F600. Many cab and trim items (glass, weatherstrip, doors, some dash, some seat, and some body panels) interchange with the pickups. But fenders, sometimes hoods, floors and cab mounts are different. \\
F61 = F600 gas, 4x2
E = 361 2V FT gas V8
C = Ontario Truck Plant
N80919 = 1972 numerical series, March 1972 production
194 = 194 inch wheelbase
No color code--probably part of the special order
F612 = F600 gas, 4x2, 23,000 lbs GVWR, "Except State of PA"
4 8
4 = Black Vinyl
8 = Standard Cab, Chassis cab vehicle
2 = Clark model 282V five speed direct transmission
E2D
E2 = Eaton model 16244 two speed rear axle, 17,500 lbs capacity, 6.17 / 8.58 ratios
D = Ford-Rockwell (Timken) front axle, 7,000 lbs capacity
23000 = 23,000 lbs GVWR
182 3800 = 182 Certified Net HP @ 3800 RPM
580585
58 = Twin Cities District Sales Office
0585 = Special Order Number
Of course not much of this matters as it looks like you have a shell of a cab only.
I can't find much on crew cabs for that year, and nothing in the model or body code indicates crew cab. I did find a post regarding another '72:
https://www.ford-trucks.com/forums/1...l#post15413818
Short version: Converted by Ford or sent to Crown Coach.
What are your plans?
Old Jun 21, 2024 | 08:22 PM
Djdjd12345's Avatar
Djdjd12345
2nd Gear
The plan is to use this donor cab to make the crew complete then find a chassi to put the cab on. Would like to build it.
kbatterman
Large Truck
Jun 4, 2024 01:23 PM
sheetmetal_gov
Large Truck
Jul 18, 2023 02:38 PM
Chadhcanterbury
Large Truck
Feb 4, 2023 03:06 PM
1949Red
Apr 15, 2021 11:01 AM
BRACKBUILT
Large Truck
May 17, 2018 09:36 AM
