1977 super cab leaf springs
Old Jun 16, 2024 | 06:32 AM
Adamsson_00's Avatar
Adamsson_00
5th Gear
Hey all,
I have a 1977 f-250 super duty rear wheel drive, trailer special, 460 with a c6 trans.
one ply is cracked and the center on the remaining ply’s are getting pretty thin and I’m worried about the main leaf breaking. So I’m looking to replace the rear leaf spring packs. The are 3” wide, 5 springs per side, and I believe they were rated for the heavier spring rating (2450)
rock auto and a few other sites no longer have listings for the replacement springs for the 2wd trucks. So where can I find some, or would this be a good time to upgrade my factory rear springs to something else? Maybe leaf’s off a newer truck, etc.
thanks in advance
Old Jun 16, 2024 | 08:36 AM
OMFDave's Avatar
OMFDave
Trailering
Best bet would be the Bronco Graveyard, one of the resources for these old trucks.
https://broncograveyard.com/?gad_sou...SAAEgLDHPD_BwE
Old Jun 16, 2024 | 08:44 AM
Adamsson_00
5th Gear
I checked there and didn’t see a listing for 2wd trucks, although I thought I had seen the previously.
I checked out the Dorman site and their listings are for both, are the rear springs the same for 2wd and 4wd?
Old Jun 16, 2024 | 08:46 AM
OMFDave's Avatar
OMFDave
Trailering
These are 2wd but not camper special, if that's important to you.
https://shop.broncograveyard.com/mob...uctinfo/23240/
Old Jun 16, 2024 | 08:48 AM
Adamsson_00
5th Gear
Those are also f-150, I’m not sure if they are the same length or not
Old Jun 16, 2024 | 08:57 AM
OMFDave's Avatar
OMFDave
Trailering
They are, all the trucks and Broncos springs were all the basically the same.
If you look on the page the measurements are provided, so you can verify
Old Jun 16, 2024 | 09:22 AM
5851a's Avatar
5851a
Old Jun 16, 2024 | 09:32 AM
Adamsson_00
5th Gear
Thanks, I see that now, those are only 2.5” wide and I need the 3” wide springs. Not sure if the 4wd springs
Old Jun 16, 2024 | 09:34 AM
OMFDave's Avatar
OMFDave
Trailering
Of all the trucks I've had none were 3" wide, but I've never had a camper special. Have you measured your springs?
Old Jun 16, 2024 | 05:39 PM
Adamsson_00
5th Gear
I did yeah, they are 3” wide, not sure on the thickness due to corrosion and rust, but I figure they would have been rated for 2450 pounds, but they don’t need to be that heavy anymore. Something is telling me they are 3” wide on the 78-79 and the 77.5, but I could be wrong on that.
Old Jun 16, 2024 | 05:52 PM
OMFDave's Avatar
OMFDave
Trailering
I guess I was wrong, looks like the 4x4 springs are 3" wide, the 2wd are 2.5", guess I never really paid attention to that before!
69 Crewcab
Dec 2, 2018 01:44 PM
ncl
Sep 15, 2013 01:47 PM
LongTravelHighboy
Apr 1, 2011 09:41 PM
89MustangGX
May 11, 2004 09:21 PM
darkrebel
Mar 2, 2004 09:52 PM
