Valve Help 352 FE
Old Jun 16, 2024 | 12:16 AM
Huckle's Avatar
Huckle
Valve Help 352 FE
Been chasing a ticking sound for a while on rebuilt 352. After adjusting lash on rockers and making sure rockers, lifters, and push rods were problem free, I pulled what I think is the problem exhaust valve spring on #4 cylinder while heads were in the truck to inspect valve stem. Everything looked good according to my untrained eye. Umbrella seals, hardly any lateral movement in guides. I have couple questions: Does anyone know what the specs are on the exhaust valve based on "1355" stamped on the stem? I have C6AE-R heads and curious if larger valves were installed on the rebuild 15 years ago according to previous owner. Also, on a different intake valve, the valve sticks closed when I pull up on it. I have to tap it to drop it back down. Feels like varnish holding it closed. Doesn't have that metal sounding ping when I pull up on it like the exhaust valve. Could this cause my ticking? Trying to attach some photos and videos.
File Type: mov
File Type: mov
bulletpruf
Jan 5, 2023 01:32 PM
jonezzzman
Jan 3, 2015 09:52 AM
wvbogger
Oct 26, 2006 12:54 PM
poboy
Jul 18, 2006 06:50 PM
Seifferlein
Jan 3, 2003 11:16 PM
