injector size suggestions
Old Jun 11, 2024 | 10:55 PM
wwhite's Avatar
wwhite
Use a rubber tire valve < $1. A can of what ever, and your battery, here is alink Poor Man's fuel injector cleaner - PlanetNautique Forums
Rubber tire valve goes over your injector inlet.
Here is a picture, I did it with my injectors, works great.
Old Jun 12, 2024 | 09:16 AM
1Butcher's Avatar
1Butcher
If you are going to DIY clean the injector, I would blow the fluid backwards. There is a filter inside the injector [should be] and forcing the debris to go through the filter and into the nozzle is probably not a good thing. Reverse flowing should be better. Of course, if you are going to replace those filters, then maybe it does not matter.
Old Jun 12, 2024 | 03:06 PM
xlt4wd90's Avatar
xlt4wd90
I've done this too, but it's hard to aim the straw on the spray can into the injector's pintle. Also, for this to be effective, the injector has to actually open.
Old Jun 12, 2024 | 08:37 PM
Conanski's Avatar
Conanski
Start with compressed air, if the injectors pass that then no need to go any further with a cleaning seeing as they are "like new". With the motor trying to run on starter fluid the next thing I would look at is fuel pressure at the rail, have you checked that?
Old Jun 13, 2024 | 01:39 AM
4x4man514's Avatar
4x4man514
Yes i have 40 pounds at the rail. I pulled tbe imjevtors and tried to blow air through energazrd or non energized. It would go. Would click either
Old Jun 13, 2024 | 05:19 PM
wwhite's Avatar
wwhite
FYI, I bought Deka 80s for my 351, because if I upgrade to a turbo I’m set. 60s might not be enough, I’m a fan of doing it once and done.
i have full tune capabilities and putting in injector data is key, as well as MAF data.
I kept mine as SD.
since you don’t have a tune, you’d be best to go with quarter horse for DIY or pimp possibly less learning curve.
Either way, you need a tune, and need to verify your eec pin out and wiring harness is correct.
Old Jun 13, 2024 | 05:23 PM
wwhite's Avatar
wwhite
What distributor are you running?
Old Jun 13, 2024 | 05:30 PM
wwhite's Avatar
wwhite
Do you have 12v to the injectors?
When the eec fires an injector, it grounds it, and I believe it is from the pip signal from distributor.
Old Jun 13, 2024 | 06:05 PM
4x4man514's Avatar
4x4man514
I kept mine as SD.
Im sure ill have to get a tune to get it right. Right now im just trying to get it started so i can maybe get it somewhere to get a tune. Seems im hearing quarter horses aren't available anymore. Seems alot of people are goi g tweecer
Old Jun 13, 2024 | 06:06 PM
4x4man514's Avatar
4x4man514
its a factory distributor
Old Jun 13, 2024 | 06:07 PM
4x4man514's Avatar
4x4man514
Old Jun 13, 2024 | 06:08 PM
4x4man514's Avatar
4x4man514
I am getting 12 volts to the injectors. The noid light shows im getting signal there.
Old Jun 13, 2024 | 11:28 PM
  #28
Conanski's Avatar
Conanski
So that worked or it didn't work?
Old Jun 14, 2024 | 03:36 AM
  #29
4x4man514's Avatar
4x4man514
no it didnt work. My auto correct changed my wouldnt both times
Old Jun 14, 2024 | 08:42 AM
  #30
Conanski's Avatar
Conanski
AI is already taking over... we're doomed!!
Time to try another set of injectors.
