surging
Old Jun 10, 2024 | 02:35 PM
RJB_1's Avatar
RJB_1
Trailering
surging
2000 F350, 180,000 miles, manual trans
I was moving the trailer today and had a surging issue. the truck RPMs erratically started surging at idle. If I applied power to the throttle in an attempt to move the trailer (30 ft gooseneck horse trailer) the truck died. It started right up, but sill surged for a couple minutes then went back to normal. any suggestions?
The batteries were low and the truck had to be jump started, could low voltage be an issue? the batteries are 5 years old so they are getting replaced today.
Old Jun 11, 2024 | 12:27 PM
RacinJasonWV's Avatar
RacinJasonWV
I would start by checking the oil level. Low oil will not let the injectors fire. After warning up a bit the level will be a bit higher. That’s my logic anyhow.
Old Jun 12, 2024 | 04:53 AM
udsuth78's Avatar
udsuth78
I'd /go over all your battery connections, alternator charge cable, and every ground lug you can find with a brush and contact cleaner. The electrical kind not the optometry kind. Could have been a low voltage combined with loose or dirty connection.
Super Guest
2015 - 2020 F150
Jun 10, 2024 04:08 PM
bobv60
Mar 3, 2020 08:24 AM
phantomqa
Feb 15, 2020 10:02 PM
papajoemrt
1997 - 2003 F150
Aug 1, 2009 12:44 PM
Lizardking
13
Aug 8, 2007 10:09 PM
