1978 - 1996 Big Bronco
Rich smell?
Old Nov 27, 2003 | 12:18 AM
kameronth's Avatar
kameronth
Rich smell?
I can not stand the way my truck smells. I just adjusted the timing which was not even off that much and it still has that nasty rich smell to it. What are some other things it could be?
Old Nov 27, 2003 | 12:36 AM
steve83's Avatar
steve83
Old gas, water in the tank, worn rings, worn valve guides/seals, wrong spark plug, weak coil, bad ignition module, bad plug wires, bad PCV valve, head gasket leak, cracked block/head, bad sensor(s), vacuum leak, bad EGR valve, fouled cats, ...
Start by pulling the codes.
dragford
15
Jan 10, 2017 07:32 PM
anthonym92
Jun 14, 2015 08:40 PM
1990-f250
Mar 12, 2014 10:16 PM
ldfry001
Sep 14, 2013 09:51 AM
Shwan_89HD
Sep 24, 2012 07:55 AM
