2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Powerboost additional maintenance?
Old Jun 8, 2024 | 02:25 PM
WXboy's Avatar
WXboy
So school me on these Powerboost trucks. Does the regenerative braking system require more extensive or more expensive brake caliper or pad or rotor maintenance? What about oil and filter changes are they the same as the standard trucks? Is there anything additional on the powerboost trucks that I may not be thinking of that would cost a guy more money over time versus a non hybrid 3.5?
Old Jun 9, 2024 | 09:22 AM
seventyseven250's Avatar
seventyseven250
Well, the regenerative braking doesn't use the "brakes" at each wheel, so in theory those should last longer, although I'm not sure if that's significant in this truck. It's basically a form of "engine braking" really.
Old Jun 10, 2024 | 06:53 AM
WXboy's Avatar
WXboy
I test drove one. 28k miles on the clock. Was a little surprised at how non-linear the feel was. Throttle was twitchy, probably because of that motor sandwiched between the engine and transmission I'm guessing. The brakes were "grabby" and non-linear also. I'm guessing this also was due to the regenerative braking system and/or the totally different brake booster design. It just didn't drive smoothly at all. Cool truck with lots of cool tech, but the driving experience didn't blow me away. And I wonder about the longevity of all that on-board tech. In 5 more years, will a guy be able to find one of those battery packs? Have dealers finally figured out how to work on these? Will the additional wiring and systems be available later down the road when repairs are needed? Will it cost a fortune to keep this on the road long term? Those are the thoughts I have. Love the interior and features, but I don't think it's the truck for me.
Old Jun 14, 2024 | 05:49 PM
RossRR's Avatar
RossRR
My truck does not experience either of those "twitchy" conditions (accelerating or braking) in normal mode so I would stay away from a truck that does exhibit them because there is likely something wrong. I do think it will cost a lot to maintain one once it is old enough for parts of its many systems to start to wear out. I got it for the ProPower because I got tired of loading my 100 lb Honda generator into my previous truck when I went camping. I've used it several times on DIY projects for powering my compressor and power tools and really appreciate what it lets me do.
I will say that I do not like to drive it in sport mode because then it does get sensitive to throttle input and will really snap your head back if you hit the throttle hard. In my youth I would have thought it was great but in my more advance years I don't need the head rush.
Old Jun 15, 2024 | 05:03 PM
JFScheck's Avatar
JFScheck
5th Gear
2024 updates mention improvements to Powerboost engine/motor handoff for more seamless transitions - anyone say firmware update? 😉👍🏻
Stanggt24
Mar 2, 2014 09:24 PM
Milwaukee1979F150
Jan 14, 2010 05:17 PM
CCBennett_1
2004 - 2008 F150
Jul 17, 2009 09:58 AM
Supercrewzin01
2004 - 2008 F150
Sep 6, 2008 10:23 PM
