bad mileage
Old Nov 25, 2003 | 07:46 PM
lrd56's Avatar
lrd56
bad fuel mileage
i have a 77b600 bus with a 330xd motor and allison at540 trans thats a 4speed automatic the carbis a holley 2300 with a vacuuum govenever in the dist but the dist is sealed the bus gets 3 to 4 on the highway and on flat ground the bus will go 68 mph wow thats fast but on the hills it will only go 35 mph what can i do i was told that the govenered dist is adjustable but where i live if its more than 10 years old it doesnt exist and i havent found anybody who knows how to work on it
help please! the 2300 holley has #55 jets in it could that be the problem also the accelerator pump is a 50cc
thank you
Old Nov 26, 2003 | 07:51 AM
Freightrain's Avatar
Freightrain
#55 Jets is pretty lean for fuel. That is not the problem. The problem is it's a BUS and it's underpowered. You probably have your foot in it to go anywhere. That's the problem.
As for dist., sorry no help here.
Larry
Old Nov 26, 2003 | 05:29 PM
willowbilly3's Avatar
willowbilly3
Ird56, I thought you traded thay behemoth for a caddy engine and tranny.
Most school buses get 7-8 mpg reguardless of conditions.
Old Nov 26, 2003 | 05:58 PM
lrd56's Avatar
lrd56
yellow beast
it looks like the trade may not go thru so i was asking questions on what to do just in case .also since the bus gets 3-4 how much better should the truck get with the bus motor and trans with 3.90 gears. im trying to find a dana 60 with 3.33 to 3.54 gears to get the best mileage and with the governor being non adjustable will i be still be limited to 68 mph .you know how most truck drivers are if your smaller than them or slower than them run them over at least thats the way it is where i live
Old Nov 26, 2003 | 08:04 PM
willowbilly3
The 3.33 gears are only aftermarket for a dana 60 but a 61 is very similar and has the taller gears. Why don't you try to ditch all that governor stuff and just put a carb and dist, off a 352 or 360. I am not sure if the distributors interchange but you could pull it out and compare. I would almost bet that allison is robbing enough horsepower to account for some of the mileage loss. Even a C6 can rob 25 horsepower, or more.
Old Nov 26, 2003 | 08:39 PM
lrd56's Avatar
lrd56
what is a 61
is the 61 a 8 hole rear end im asking because ive never heard of it . the holley carb on the bus is basicly the same as the holley that came off my 390 it just has two more vacuum ports . unfortunatly the only dist that fits also fits the 361 and the 391 the hole in the manifold is too big for a fe dist. im trying to find someone who knows how to adjust it .there is a plug on the side of the dist i dont know if thats where to adjust it i dont want to break anything im probably being too cauthius .the motorcraft code is d4te-aha-a-7e23.the holley #list -5817-1.i know i ask a lot of questions but ive had gm for too long .i dont know ford very well
thank you for your help
Old Nov 26, 2003 | 11:10 PM
willowbilly3
I haven't actually ran across a Dana 61. I just read that it was the same basic thing as a 60 but in the newer pickups and specifically for the taller gears.
If a different manifold is required to use a pickup dist then maybe you should try it.
Old Nov 26, 2003 | 11:43 PM
BB's Avatar
BB
The hole inside the engine is also bigger for the FT dist. shaft where the gear goes on. Ford still sells a bushing to sleeve down that hole to the FE size, I used to have that pn, will find if if you need it. Will also try to find some info on that FT dist.
Barry
Oops, just noticed this thread got hijacked, will try to split it.
Old Nov 27, 2003 | 01:18 PM
lrd56's Avatar
lrd56
ft to fe dist
hey bb please look for the ford pn# also if you find where to adjust the adjust the ft dist .thank you
Old Nov 28, 2003 | 02:16 PM
BB's Avatar
BB
Here it is, C4TZ-12367-A
On the dist, remove the plug and you should see an adjusting nut inside. You may have to bump the engine over for the nut to line-up with the hole. Backing the nut out should increase the speed. If it doesn't turn I wouldn't force it 'cause if it breaks off you'll be looking at a new dist.
Barry
Old Nov 28, 2003 | 02:49 PM
BB's Avatar
BB
Was just thinking (sorry for being so scatter-brained)
An FE manifold won't match up correctly to the FT heads you got, the exhaust heat crossover is completely different along with the water neck and water pump plumbing.
Barry
Old Nov 28, 2003 | 03:27 PM
lrd56's Avatar
lrd56
bad mileage
hey bb thanks for the info that where i thought the the adjuster was but i didnt want to break anything i was told max rpm is 3900 is that where i should set it my chiltons says 186 hp at 4000 the altitude where i live is 4100 ft thanks
Old Nov 29, 2003 | 12:33 PM
lrd56's Avatar
lrd56
governer adjustment
i found the adjustment and i found the right direction now the bus runs about 74 mph and up the hills with the pedal to the floor it runs 50 to 55 and the allison didnt shift down i think thats a big improvement by the way the direction is turn it in. i turned it in all the way now i have to find a cheap tach to find the max rpm
thank you
mike davis
Old Nov 29, 2003 | 12:51 PM
BB's Avatar
BB
Thanks for the update mike. I wasn't exactly sure which way to turn it, all I had were exploded diagrams and was taking an educated guess on the direction, oh well.
Barry
Old Nov 30, 2003 | 02:52 AM
willowbilly3
If the engine will turn 4000 that should be plenty of rpm to get you a speeding ticket with even a 4.10 gear in your pickup. With a 4.10 and 31 inch tires you would be turning about 2700 at 60 if my calculations are correct.
