Quick Fuel Tank Question
If the provisions are there, I bet somewhere in the world are trucks with tanks hanging on that right side.
Was this an option ?
From all appearances, one could have three tanks under there; one each side of the drive-shaft and the one between the rails behind the rear axle.
I haven't studied close enough to verify; but, I bet that left side tank could be swapped end for end and mounted on the right side.
1 - the EXH runs down the right side and because the tank is on the left side you dont see true dual EXH on a Ford,
2 - and the biggest I see with gas, Diesel maybe not so big? Is how do you fill both sides?
You would need to fill 1 side, put the nozzle on top of the pump to turn the truck around and how no one pulled in when doing this and forget it if you go a trailer!
Hose are not long enough to reach over the bed and forget if you have a bed camper or cap.
Chevy did this on some of think late 70's early 80's and was a big problem.
Now I say diesels may not be an issue if you live near a truck stop.
The truck diesel Inland has fills on both sides as big rigs have tanks on both sides and they fill fast even on a slow setting so that can be a issue for pickup trucks that dont vent well to start.
I think if you need a 3rd tank a in bed tank is the way to go with the fill on the left side
Dave ----
As for the Chevrolets with dual tanks, I started my long-hauling cattle career with a 1978 Chevrolet that had a single 16-gallon left side tank.
On a long trip, I spent more time paying for gas than I did getting to where I was going; and, I was always afraid of running out of gas.
Then I got a second Chevrolet, this one a 454, with the same single 16-gallon tank. and that truck was an ever-present danger of running out; yet, everybody who ever drove that truck with a big load behind it claimed it would outpull any truck they ever drove and could top the Gradyville hill and never touch the stick.
Always carrying a couple Jerry Cans was just a way of life; locked and chained, of course, else somebody would dump one in a tractor or lawn-mower and not say anything and there you would be expecting it to be full when it was empty.
After years and countless miles of always running on fumes, a good friend showed up one day and gave me a right side tank, brackets and all, that he had found at a junk-yard while looking for something else.
We put that tank on the first truck and I never heard anyone ever complain about having to switch sides at the pump --- we were all so glad to have twice the range that it was a small matter to have to move the truck/trailer to fill both sides.
Unless it was some place in the middle of the night with nobody else around, we never did try to keep the pump running, move the truck/trailer, and fill both sides; we just got in the habit of filling the one side, shutting the pump Off, moving the truck, and then fill the other side.
I almost never turned the truck around to switch sides; I always just backed up past the pump island and pulled up on the other side = a lot easier and a lot less confusion.
For the longest time, the 454 truck had exposed rails behind the cab, with a pair of mud-flaps back there and that was all; we found a polished Aluminum 100-gallon tank from a wrecked day-cab and strapped it behind the cab and I honestly believe cut our fuel mileage in half.
Way back when we first put that second 16-gallon tank on that 1978 Chevrolet, we thought we had fuel to spare; now, if I got as low as only 32-gallons, knots would be in my belly, afraid I might run out.
I can't understand this big fear of tanks outside the rails; gas or diesel, almost everything I ever drove has tanks outside the rails.
Seven years is pretty good for me; I found my note dated October 2017 where I decided the fuel tank was about to fall in the road and I wrapped two ratchet-straps around the whole mess to prevent catastrophe.
Ford really missed the boat on their design of this set-up; of course, it may have been intentional like the self-destruct chips that companies have been including in electronic stuff so that they cease to function properly after the warranty expires.
That thin steel shield right against the fuel tank is a recipe for corrosion and a great place to trap every bit of grit and grime and Calcium Chloride that comes along.
The fuel tank has a myriad of fuel and electrical connections, vent tube, filler, etc. all connected to it and is going to always have some amount of fuel sloshing around in it.
A quick man would want to periodically drop that plate, wash it out, wash the tank bottom, and slather a bit of Rust-Linoleum Paint on it.
However, Ford has allowed no simple means of doing that; no way to prevent the tank falling out when the shield bolts are removed, thus making it a complete act of congress to do anything to prevent the shield's eventual demise.
Funny thing is, the rear tank, tucked up between the frame and cross-members and within two inches of that big Dana 70, has little chance of damage inflicted from any source; whereas, the front tank, in a far more vulnerable location, has no means of protection whatsoever.
You're right about it being a corrosion problem. I wouldn't drop them to apply paint. I would use Fluid-Film and apply it liberally around the top and side edges. Use a spray can to shoot it in as far as possible or apply bulk Fluid-Film with an air sprayer. It spreads and seeks crevices and cracks. Neutralizes salts and stops corrosion.
I have had it for years; I guess I have been keeping it for special occasions.
It would probably be good to just load the 25-gallon herbicide tank with it and saturate everything under the truck about twice a year.
I am sure it would spray as we put diesel fuel in them to soak the dump beds just before loading black-top so it slides out instead of sticking and building up.
The guys that haul a lot of black-top forego the chemical tank and just plumb the spray into one of the saddle tanks.
Also back then you could back up and pull on the other side try that today and see what happens.
Also if you pay by CC and shut the pump off and then move and try and use the same CC o to fill the other side somethings it will not take the CC as they liknk someone stole it.
I have had that happen where I got gas and then when in the store to bya soda & snake and it would not take the card for that reason.
My .02
Dave ----
My .02
Dave ----
I know what a soda is; what is a "snake" ?
The only issue I see is the filler may be to far forward?
Looking at the tanks above the left side of the tanks fit to the cab maybe under it as I dont remember now.
I do know you cannot put a long bed 19 gallon tanks where a short bed 16 gallon tank was as I tried on my flare side short bed truck.
Maybe if you have a long bed truck and wanted a right hand 3rd tank you could use the 16 gallon tank and move it back so the filler in on the bed side?
As they say "if there is a will there is a way"
Dave ----
The only issue I see id the filler may be to far forward?
Looking at the tanks above the left side of the tanks fit to the cab maybe under it as I don't remember now.
I don't have any of those issues to deal with on my truck with the steel flat; the filler-necks for both of my factory tanks are under the trap-door in the recess where the gooseneck ball resides.
This is an ideal arrangement when towing a gooseneck and the trap-door must be chained open anyway; but, it is not ideal when the trap-door is closed and there is something loaded on the flat that prevents the trap-door being raised; but even then, it has never posed a problem for me as I can just run on the big 52-gallon auxiliary tank.
I never really gave it a thought; but, my truck is (I believe) the longest factory-available wheel-base; and, I am now thinking that as the rails get longer, that left side fuel tank gets farther from the cab; I believe the rear end of the tank stays the same distance from the rear axle and gets closer to the cab as the frame gets shorter.
All of this front tank discussion is just discussion for me anyway; as, as soon as I get all of my little duckies in a row, I have a 6041 4-speed auxiliary that is going under there and I think the front tank will have to go as it will probably be right in the path of the new cross-member that the auxiliary hangs on.
In it's place will probably be brackets/hangers for the current drive-shaft assembly to always be there in the event something were to happen to the auxiliary and it have to be temporarily removed; if it were to fail thouwzands and thouwzands of miles from home, I can just strap it on the back of the truck and put the original shaft back in and the wheels keep rolling.
