ECT?
Old May 31, 2024 | 01:54 PM
Carstrucks07's Avatar
Carstrucks07
6th Gear
Exclamation ECT?
I have a 2000 7.3 automatic.
When pulling hard hills it heats up. The gauge seems right, because when i turn the heater on the gauge goes down and cools down. As it should using the heater core like a radiator. So looking at the gauge I semi trust it. Using the FORScan program i look at the live data. The coolent tempeture is completely off and not right. The gauge on the dash looks perfect, at operating temperature. But the live computer data shows it into the negitives (-246) or sometimes at really high numbers (275). When looking at the oil temp on the computer that looks right. (About 200). So something isnt right about how the gauge works and the ect temp going to the pcm.
when i put a jump between the 2 connecters on the ect harness the gauge goes up
immediately. So i think the gauge and the wire going to it are working as they should.
Could this be causing my shut down problem?
sometimes the pedal will have no response. But the truck is still idling for about 20 seconds.
I have also been deaing with a over heating problem. Ive replaced every component in the cooling system. multiple fan clutches. and so many other parts It only overheats when Im pulling a big hill with my trailer. But it would never do this on these same hills before.
Old May 31, 2024 | 03:53 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
There are plenty of threads in this forum about inaccurate ECT values on the datastream.....because the PCM on your vehicle doesn't have an input for it.
The only time I see overheating/heating up issues on these is when the area between the radiator and charge air cooler ("intercooler") is plugged with debris like chaff, grass, cotton, grasshoppers, etc.
Old Jun 1, 2024 | 01:19 AM
JoshHefnerX's Avatar
JoshHefnerX
The coolant temp gauge is a derived number. Oil temp is what you can watch. Think most people like to keep the oil temp under 240..
Old Jun 1, 2024 | 04:55 AM
udsuth78's Avatar
udsuth78
You might want to check the turbo compressor wheel spins free and doesn't have any play or damage. Also look for any signs of boost leaks at the intercooler piping connections. Then check for exhaust leaks around the manifolds, up pipes, and collector. I've seen low boost cause warm up at highway speeds pulling a load. Of course the root cause then was the guy driving like a 90 year old lady on a Walmart scooter. Kinda hard to spool a turbo without a few rpm's.
Edit: Oh yeah check the air filter too. Engines gotta breathe just like everything else.
Old Jun 1, 2024 | 07:09 AM
RacinJasonWV's Avatar
RacinJasonWV
Can you elaborate and list the parts changed for the cooling system? “Every component” is vague and means different things to different people.
Did the overheating start after some part was changed (even unrelated to cooling system), or did it begin randomly before anything was changed?
How about some photos of the setup. The guys here are pretty good at spotting things that are amiss.
I believe it was @Kwikkordead who had an issue with a slipping belt causing cooling trouble.
Has your tensioner been replaced? De-glazed the pump pulley?
Personally I’m with Cleatus on team “airflow restriction” for the radiator. Even if you changed the radiator there are parts in front of it that can be plugged and impede flow.
Old Jun 1, 2024 | 08:36 AM
Kwikkordead's Avatar
Kwikkordead
Subscribing. Nothing to add to what has already been said. Need to know the specifics of what has been replaced, etc. Whether there is debris blocking airflow over the radiator, etc. I have had to remove the radiator twice now and clear the debris that gets stuck in the fins. And yes, the pulley on my truck was smooth as glass and I really wish I had known about deglazing the pulley 15 years ago now. It would have saved me a lot of headaches.
Old Jun 2, 2024 | 12:57 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
As others mentioned, the scanner cannot show coolant temps. The PCM only monitors oil temp so you could read that. The coolant gauge on the dash is a simple old school sensor/wire/gauge dealio. Sounds like it's working fine.
This is not related to your lack of throttle. That sounds more like a dirty throttle position sensor. I'd spray some contact cleaner in the switch, let it dry, and see how it goes. Also clean the Idle Validation Switch since you're there.
I'll attach a PDF with some good info and pics.
File Type: pdf
99FordDually
Sep 4, 2021 08:18 AM
Cimarron
15
Sep 1, 2011 01:10 PM
PRUSue
Feb 20, 2011 08:22 PM
pistol pete
Dec 23, 2004 09:58 AM
subhuman
1983 - 2012 Ranger & B-Series
Mar 21, 2003 11:11 PM
