Power steering bracket
Old May 29, 2024 | 05:36 PM
hollis's Avatar
hollis
5th Gear
I have an '86 f250 6.9L with a fractured power steering bracket. It appears that it was metal fatigue, as it has not been in an accident. I discovered it when I could not tighten the belts to my satisfaction.
I've seen one on eBay, but for a smaller motor. Short of junkyards, are there other sources I should look into first for a replacement part?
Thanks!
Old May 30, 2024 | 12:15 PM
gespeter's Avatar
gespeter
Mine was cracked by a previous owner doing a rough engine swap. I had it welded back to original strength, but noticed the thing flexes if I tighten the belt a lot. Things just weren't built that stout in the first place. Leaving my belt tension (Goodyear Gatorback) loose enough to slip at full lock because I fear it might break.
planning on somehow adding gusset(s) but I don't own a Heliarc.
Dan67
Jul 9, 2022 05:44 PM
Rotorpilot
Apr 20, 2022 12:44 PM
BossFan
Aug 8, 2011 09:06 PM
1960 Ford F100
Sep 24, 2003 01:29 AM
