Can't clear codes
Old May 27, 2024 | 06:34 PM
bc3927's Avatar
bc3927
5th Gear
Can't clear codes
I replaced the instrument cluster after failing to fix original. I learned about how to program PCM, cluster and keys - I actually purchased a rebuilt PCM (programmed for my 2004 F150) - it didn't work as well as my original PCM so it's back in there. I kept getting numerous codes through my OBD reader and Forscan. I drove the car for over 500 miles to try to "re-program" my PCM. The truck drives "OK" but every time I clear the codes - they return.. Through Forscan I see the following codes: (OBDII _ P0135, PO141, PO155, P0161, P0340, P0403, P0446 --- PCM P0340, P2006 ,P0443, P0446, P1000, P0135, P0141, P0155, P0161, P0403 AND GEM B1302, B1398, B1428, P0500. Any thoughts/recommendations on how to clear codes??? THANKS
Bob
Old May 29, 2024 | 09:16 AM
projectSHO89's Avatar
projectSHO89
First, find and replace the blown fuse. Probably F32 under the dash. If it continues to blow, you'll need to find the short circuit and repair it. O2 sensor wires on the exhaust is a pretty common cause.
Joshb2020
6.7L Power Stroke Diesel
Jun 13, 2024 04:19 PM
terry br
Oct 19, 2022 02:19 PM
drzdave
Apr 23, 2010 08:09 PM
96f150
2004 - 2008 F150
Jun 2, 2007 08:54 PM
cathlabdog
Oct 25, 2006 07:20 PM
