460 Distributor Drive gear
Old May 26, 2024 | 11:46 AM
Pappawheely's Avatar
Pappawheely
Installing a new distributor in my 92 460. The original distributor has a phenolic/plastic drive gear. The new one has a hardened steel gear. Should I swap the gear from old to new? I'm pretty sure the engine has a stock cam.
Old May 27, 2024 | 07:16 AM
manicmechanic007's Avatar
manicmechanic007
The original gear should be cast iron (you have non roller cam engine)
That means you should use a cast iron gear and not steel
That steel gear will tear up the cam gear
Rusty_S
Nov 11, 2022 01:43 AM
James Wagoner
Oct 8, 2020 02:34 AM
490SCJ
Missouri Chapter
Feb 4, 2005 11:27 AM
490SCJ
Jan 5, 2005 01:37 AM
eltweedy
Dec 24, 2000 08:38 AM
