Rear bench swap fit?
Old May 23, 2024 | 02:17 PM
kd5zll's Avatar
kd5zll
2005 60/40 rear bench, onto an e99 full bench. Only reason im considering is to get the rear headrests, since one kid is already tall enough amd another will be soon, where the headrest is an actual safety plus, imo.
Old May 23, 2024 | 02:29 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Is there another question in the post?
The answer to the question in the thread title is yes. A 2005 rear seat will bolt up to a 1999 cab. Look at the cab floor from underneath the truck, and you will see that there are already bosses for intermediate mounting bolts welded to the cab floor. Those bosses will align with newer model year seats that are split configured.
Old May 23, 2024 | 02:38 PM
ESwift's Avatar
ESwift
CNCFAB
I did this 2013 rear bench in my e99 the other year. Worked out well, had to get the brackets and what not for the center shoulder harnedd
https://www.ford-trucks.com/forums/1...t-options.html
Old May 24, 2024 | 08:34 AM
FordTruckNoob's Avatar
FordTruckNoob
Have them wear this. No headrest required. Works with 3-point seatbelts. May break your rear glass on the backlash though.
Old May 24, 2024 | 04:48 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
You stirred a memory; had a '65 F250 that I swapped in a '64 Lincoln 430 engine/trans. When it came time to sell I told the guy to ease into the throttle. Sure enough as he and his wife and kid drove off he hit the pedal too hard and BAM all 3 heads hit the back glass.
decker
Sep 11, 2014 11:10 PM
AZ Wildcat
Aug 4, 2014 09:27 AM
cecilt
Mar 11, 2011 12:36 PM
96f-250
Feb 13, 2009 04:36 PM
dlj31
May 18, 2005 08:37 PM
