Hood insulation
Old May 22, 2024 | 11:08 AM
Alblooki's Avatar
Alblooki
Hood insulation
Hi, what is the best insulation for the hood for 1956 Ford f100?
Old May 23, 2024 | 08:43 AM
52 Merc's Avatar
52 Merc
Our trucks never came with any kind of hood insulation from the factory. Why do you feel the need to add insulation? The only real reason the factory adds it is to reduce noise, which is not typically something you're going to control well in our old rattily pickups.
Old May 23, 2024 | 12:32 PM
Alblooki's Avatar
Alblooki
I want since my 56 f100 is engine swapped and it gets hot in the cabin.
Old May 23, 2024 | 12:54 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
That's what the cowl vent and windows are for :-P
If you want to augment the factory setup, there are these or similar products that in combinations would seem to address your issue, but your budget may not align:
https://collectorsautosupply.com/hoo...oustihood-kit/
https://collectorsautosupply.com/fir...sulator-front/
https://collectorsautosupply.com/fir...k-made-in-usa/
https://collectorsautosupply.com/hoo...955-1956-ford/
Old May 23, 2024 | 03:56 PM
52 Merc's Avatar
52 Merc
It would be far more effective to add additional thermal barrier and insulation on the firewall and floor, and the roof and back of the cab if you live in a hot sunshine area, than to try to mess with the underside of the hood. Those would be the areas that the heat is coming from, not the hood. My 2c.
Old May 23, 2024 | 04:41 PM
abe's Avatar
abe
Agreed. I bought an abs insulated firewall pad that fit perfectly and looks original. It really cut down on noise and engine heat.
Old May 24, 2024 | 05:04 AM
Alblooki's Avatar
Alblooki
True, since most of the heat comes in the cabin from the firewall and my floors already have insulation.
Old May 25, 2024 | 08:04 AM
F100supercrew's Avatar
F100supercrew
hood insulation
DO NOT NEED IT-- I use this in everyone--
Dixon1948
Jan 21, 2020 05:16 PM
fergusonicford
Feb 11, 2008 08:36 PM
