1961 ford f250
Old May 21, 2024 | 12:51 PM
Adeleon's Avatar
Adeleon
1st Gear
1961 ford f250
Recently inherited a 1961 ford f250 and looking to restore it. Is there a newer truck frame that would be easiest to swap with? Also looking for the specific bed for this truck. I think it is a 7' bed. Thank you
Old May 21, 2024 | 02:49 PM
Fomoko1's Avatar
Fomoko1
Moved to this forum.
Old May 21, 2024 | 05:49 PM
john jamieson's Avatar
john jamieson
From your description I'm guessing your truck is not a unibody. If it had a bed, it would have had the earlier style bed, from the ''57 to '60. These are often called wrong beds, since the body lines don't line up. I don't believe there was a 7 foot bed. It would be a 6.5' (?) or 8'.
Old May 21, 2024 | 05:53 PM
TA455HO's Avatar
TA455HO
Lead Gopher
No short wheelbase F250s so 8' bed should be correct whether unibody, wrong bed or flare side.
Old May 21, 2024 | 07:14 PM
53deere's Avatar
53deere
The 61 cab is not a direct bolt on to any newer truck chassis. It can and has been done though and in general the newer you go the more work it is. Anything is possible, guys mount them on Crown Vic chassis all the time.
Robb Howard
New Member Introductions
Nov 16, 2018 06:20 PM
octavius
Dec 19, 2016 09:43 AM
fisher_of_men1
Apr 28, 2016 10:27 AM
