alternator charging wire melted
Old May 20, 2024 | 11:31 PM
14WIDEZ_PAPI's Avatar
14WIDEZ_PAPI
Trailering
I have a early 1999 ford f250 super duty 7.3L the wire coming off the alternator melted. what can cause this?
individually tested batteries one read 12.2 and the other 12.3 which I know is low so have them charging at the moment.
checked the nut that holds the wire to alternator and it was tight.
while truck is running tested batteries and only reading at 13 volts
truck ran fine until a rough start this morning and than didn't start after work popped the hood and sure enough the wire melted. crimped a new fitting on and jumped the truck just to make it home.
edge cts3 was reading voltage at 12.8 - 13.8 while driving home.
brand new alternator cause the battery light came on about a week ago. just replaced all the terminals due to old age and starting to deteriorate.
ever sense replaced alternator voltage has been reading lower than normal. it used to stay between 13 and 14 now its all over the place which has me nervous.
while cranking this morning it was at 9.7volts on the cts3 than warmed up and stayed around 12.5. while driving to work would go between 11.8 - 13.3.
now that im home switched to forscan so I could check everything while also checking voltage.
ICP reading 588psi IPR reading 12.89% engine voltage 13.06
ICPV 652psi
truck has a lot of performance parts but not much after market electrical has one 12" sub and the irate diesel e fuel kit wired to driver side battery. pulled all the wiring from the previous owner out.
also has brand new engine wiring harness.
forgot to check for codes ill do that tomorrow
any help is appreciated.
Old May 21, 2024 | 05:09 PM
Tpayne621's Avatar
Tpayne621
What kind of shape was the wire in? Any corrosion or anything inside of it where you crimped new wire end on?
Old May 23, 2024 | 12:18 AM
14WIDEZ_PAPI
Trailering
wire is in good shape I cut off about an inch of wire that had melted. so fresh clean wire before crimping new fitting on. checked continuity and it passed so I don't believe I need to replace the wire but in the middle of taking apart harness tracing it. I believe it goes to the glow plug relay but not done following it. the battery feed wire on glow plug relay seems really hard so i'm suspecting that one burned to.
thank you for the reply
cooksmtn
Aug 13, 2019 07:57 AM
Stuckinmud
Electrical Systems/Wiring
Sep 10, 2008 10:05 PM
natewoz
Feb 9, 2007 06:54 PM
Wodeman
Oct 7, 2005 01:31 PM
