Do I have the wrong Carburetor
Old May 16, 2024 | 07:09 PM
AzzMann's Avatar
AzzMann
So I have a 1985 f150 flareside with a 302 I can’t for the life of me tune it.
I type in the model # and this is what it shows up. For an f250 351W
Old May 16, 2024 | 07:20 PM
My4Fordtrucks's Avatar
My4Fordtrucks
What carb is on it now? Is it a 2 barrel?
Old May 16, 2024 | 07:23 PM
AzzMann's Avatar
AzzMann
yes sir. The carb pictured is on it
Old May 16, 2024 | 08:31 PM
Franklin2's Avatar
Franklin2
What's the problem? Won't idle? Won't run down the road? Floods out?
Old May 16, 2024 | 08:48 PM
elkhart75839's Avatar
elkhart75839
get the original rebuilt
send it to guaranteed carburetors in florida. they rebuilt mine and it came back looking new. Rebuilt Carburetors | Guaranteed Carburetors
Old May 16, 2024 | 09:05 PM
AzzMann's Avatar
AzzMann
High idle, won’t stay running sounds like it’s flooded, step on pedal and it stalls out.
Old May 17, 2024 | 03:57 AM
My4Fordtrucks
Have you tried rebuilding it? How long has it been since that was done?
That is who I used for the Jeep carburetor. There was wear in the throttle shaft. Excellent service. I had the carb back in a week.
Old May 17, 2024 | 06:00 AM
Franklin2's Avatar
Franklin2
I am getting the impression the carb he is using is brand new? If that is the case, why send it out for a rebuild?
When you try to run it and then it stops, look down the carb throat right after it stops with the aircleaner off. Do you see liquid fuel dripping? If you do, it is flooding.
If you do not see liquid fuel, are you having to pull the choke door back to look down inside the carb throat?
Old May 17, 2024 | 07:53 AM
AzzMann's Avatar
AzzMann
Carb is new
Old May 17, 2024 | 07:54 AM
AzzMann's Avatar
AzzMann
yes I’m having to open choke door.
Old May 17, 2024 | 08:08 AM
Max Capacity's Avatar
Max Capacity
I assume you have removed all the EFI stuff so this 85' 302 is no longer looking for EFI ?
Old May 17, 2024 | 10:27 AM
AzzMann's Avatar
AzzMann
the ford control module was replaced for hei.
Old May 17, 2024 | 01:11 PM
My4Fordtrucks
I interpreted that as the one on the truck does not match what was listed on the website.
Maybe it is some cheap Motorcraft/ Autolite clone that you will never get to run correctly. When I was a regular on a Jeep forum the guys would always complain about the Weber clones that they could not get to run right.
Old May 17, 2024 | 05:07 PM
Franklin2's Avatar
Franklin2
I ran a clone on my Bronco II (a 2100 2bbl) and I did have a few hiccups I had to address when I first installed it, but after that it ran fine for several years till I changed the engine.
Old May 17, 2024 | 05:12 PM
Franklin2's Avatar
Franklin2
Chokes can be aggravating to get right. Do you have a wire to the choke cap? If you want to take the choke out of the picture, you can loosen the 3 screws on the cap, and twist the cap while holding the throttle open (engine off) till the choke door opens straight up. Caution, once you do this, the engine will be stubborn to start and run when cold. You will have to pump the pedal to the floor 3 times before cranking cold, and then you will have to pat the gas pedal a little bit to keep it running till it warms up. If you want to try the choke in some sort of mid-position between closed and open you can. I would advise you to mark the cap position where it was when you started as a reference.
The choke has linkage on the carb that makes the engine idle fast when cold. The choke also "chokes" the air off to the engine to make it run richer when it's cold. If the choke never opens up, all this will still be in play when the engine is warmed up and there is no way you can tune it like this.
