Sponsored by: Real Truck
testing fuel injectors
Old May 15, 2024 | 10:52 AM
PJWhelan's Avatar
PJWhelan
So, I picked up a Fuel rail and 8 injectors from a salvage yard. I want to test the injectors as I also will refresh them with new O-rings and caps (hats) for the spray base. I have seen videos where they will use a 9 volt battery or car battery to get power to the injector plugs. Can I assume that a 6V lantern battery will also do the job to provide test power. It enables the injector to fire so that you can see the spray pattern. Thoughts?
Old May 15, 2024 | 03:02 PM
nydiver's Avatar
nydiver
Its a valve, all you can do is try it and if no spray goes thru them then try a higher voltage battery. Most use a 9V to do this and an aerosol injector cleaner spraying into the inlet.
Old May 16, 2024 | 07:41 PM
Baylinerchuck's Avatar
Baylinerchuck
I used 12v power source and carb cleaner with a make shift adapter to clean my Polaris injectors. I assume that would work on most anything accept the HEUI injectors.
IDI-Charlie
23
Oct 28, 2020 08:14 AM
kefrko
1983 - 2012 Ranger & B-Series
Apr 5, 2016 10:31 AM
MAD80433
1997 - 2003 F150
Mar 2, 2009 12:39 AM
fordman1954
Apr 5, 2007 05:16 PM
