2019 Super Duty
Old May 14, 2024 | 10:53 PM
PeteHCFord's Avatar
PeteHCFord
2019 Super Duty
Hello
Lariat Crew Cab 6.7
I wanted to get a recommendation to upgrade my tires. I would like to go as large as possible, but no rubbing and keep the factory wheels.
Also, I would like to level the truck. What’s the recommended leveling kit?
Thank you.
Old May 15, 2024 | 06:44 AM
WXboy's Avatar
WXboy
For a leveling kit, just use a spacer kit. I think I got mine for $25 bucks off eBay or Amazon. All they are is aluminum or steel blocks. Nothing to it. So do not overpay for a "name brand". I got the 1.5" for my 2019 and it's perfect. I still have just a very slight bit of rake which is great because I do haul and tow with the truck.
For tires, I run 35x12.50R18 and it's as close to rubbing as I could get without rubbing. Anything larger and you'll need to do some additional measures to make them fit good. When I turn my wheels I can't even put a finger between the splash guard and tire....but it doesn't rub.
Old May 15, 2024 | 08:52 AM
speakerfritz's Avatar
speakerfritz
I got 37’s on 22.5’s from buytruckwheels.
all I wanted was bigger and oem look which is what I got.
I needed high weight ratings (I got 6000 per rim) so I didn’t want ganster mattle looking die cast look.
Curated Content Editor
2023+ Super Duty
19
May 11, 2023 07:11 AM
350Muzzle
Mar 1, 2022 06:28 PM
Rdaglock
Mar 10, 2018 11:05 AM
Ron Terry
Aug 4, 1999 09:12 PM
