Maximum tongue weight pounds for receiver hitch?
Old 05-11-2024, 12:01 PM
Truck Fun's Avatar
Truck Fun
Truck Fun is offline
Question Maximum tongue weight pounds for receiver hitch?
Is there a maximum tongue weight rating in pounds when using the 2" receiver hitch on my 2014 SC, 4wd, 6.2L ? Thanks.
The following users liked this post:
Old 05-11-2024, 02:42 PM
Ted722's Avatar
Ted722
Ted722 is offline
Factory hitch ratings are 6,000 lbs trailer / 600 lbs tongue load conventional. 12,500 lbs trailer / 1,250 lbs weight distribution.
Should also have a load sticker on hitch receiver.
https://rvsafety.com/images/pdf/FordTG2014.pdf
The following 2 users liked this post by Ted722:
Old 05-12-2024, 07:24 AM
SpencerPJ's Avatar
SpencerPJ
SpencerPJ is offline
If you are asking what max weight you can add to your truck, that is listed in the drivers door (might be called carry capacity). If you are asking max weight you can put on the steel hitch, see post#2.
Old 05-12-2024, 01:13 PM
Truck Fun's Avatar
Truck Fun
It was just for the replies and info. Question was for max weight to be put on the receiver hitch. The sticker on the oem receiver hitch is long gone.
Old 05-13-2024, 12:58 PM
Ted722's Avatar
Ted722
Ted722 is offline
Below is the sticker on my '03 F250.
Considering the rating stamped on the chrome bumper w/ball screwed into it is 5,000 lbs trailer / 500 lbs tongue load, the Ford hitch / receiver weight carrying ratings seem awfully conservative. Essentially, Ford saying anything over 6,000 lbs a WDH is recommended, not that it can't handle higher load without WDH.
Don't forget the rating on the ball mount hitch that slides into the receiver. My 2" hitch (5" adjustable drop/rise B&W tow & stow) I've been using has these ratings:
2" inch ball rated at 7,500 lbs trailer / 750 lbs tongue load
2-5/16" ball rated at 10,0000 lbs trailer / 1,000 lbs tongue load
CamperWill
1999 to 2016 Super Duty
01-01-2024 03:28 PM
6door74
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
01-12-2018 07:13 PM
rdinmv
03-14-2014 08:31 PM
Ferguson65
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
03-25-2007 07:47 AM
fornarog
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-31-2004 09:39 AM
Quick Reply: Maximum tongue weight pounds for receiver hitch?
