Shaft diameter of FE distributor?
Old May 4, 2024 | 11:27 PM
DrCharles's Avatar
DrCharles
Question Shaft diameter of FE distributor?
I'm building a 390 from a pile of unrelated parts... long block is together, intake ready to go on.
I bought this new distributor, planning to convert my '65 F-350 to Duraspark:
https://www.rockauto.com/en/moreinfo...120756&jsn=450
...and it won't go into the block!
No, it is not hitting the oil pump driveshaft. It's almost an inch from seated. Cam gear isn't engaged either.
What I think is happening is that the end of the shaft is bigger than the small hole in the block. So either it wasn't machined correctly, or for some reason the block bore isn't big enough. Given the country of origin and the low price, I suspect the former.
Does anyone have an FE distributor they can measure the snout diameter? Aren't they all the same for FE's... thanks.
Old May 4, 2024 | 11:46 PM
85e150's Avatar
85e150
Maybe you got an FT distributor. The drive is 5/16 vs 1/4 for FE. Check the shaft.
More later gotta go.....
Old May 5, 2024 | 09:05 AM
DrCharles's Avatar
DrCharles
Thanks, but the oil pump shaft is definitely 1/4". More importantly, the shaft is nowhere near engaging with the hex socket in the snout.
On fordfe.com, I received some actual measurements. Hole in the block is .453 and the pilot diameter is .450.
Now to measure the distributor I got! Also more later
Old May 5, 2024 | 10:39 AM
DrCharles's Avatar
DrCharles
Found the problem. Hole in the block measures at .451 with a telescoping gauge and micrometer... but the snout is .454 and a few tenths! Offshore manufacturing tolerances
I considered slightly enlarging the hole. But then I noticed the distributor also has no indexing tab for the cap! Don't know if that's design or sloppy assembly. Back it goes.
Destroked 450's Avatar
Destroked 450
Spectra’s description give metric measurements so distributor is probably from the land of almost right, but not quite right
Old May 5, 2024 | 10:46 AM
DrCharles's Avatar
DrCharles
yep. I shoulda known better
Is there a reasonably priced one that you would recommend? This is going in a truck, not a race car. Won't see over 4000 rpm. I installed a Pertronix module in my old engine (still in the truck) and it's worked fine for many years, but was thinking of upgrading to a Duraspark or even an HEI setup.
Old May 5, 2024 | 11:09 AM
lshort's Avatar
lshort
right now there is a really nice looking duraspark distributor on ebay for $150.00. I use one of these on my 390 and am very happy with it, proven reliable, parts easily available
ford highboy!
Nov 3, 2021 12:39 PM
wtroger
Apr 14, 2021 07:57 PM
Mylosdad
Aug 10, 2020 06:26 PM
Boundertom
18
Apr 16, 2020 09:11 PM
jamison29
Jul 7, 2018 09:06 AM
