I was in a drive though while it was rainy and my truck started to short out somewhere the truck started saying i needed to service brakes advance trac and my trailer brake module and revving weird and i turned it off and it wouldn’t start back up and 5 or so more tries to get it going it started but nothing was working on the dash only my doors when i put it in gear it took about 10 seconds for it to go in not sure what ir would be it’s a 2016 f250 6.7
A different vehicle, my son's 2015 Fusion, but one of the error messages was service advance trac as the car had multiple error messages on it but it ended up being the alternator...
Okay more detail... He had a low voltage code (soft code) prior to Steering assist fault service required, hill start assist not available and the Service Advance Trac. All caused by a bad alternator... Try reading the truck for any codes. Good luck...
