Drag Link Rebuild Question:
Old May 4, 2024 | 04:39 PM
leonharu's Avatar
leonharu
I had to have the drag link rebuilt and pitman arm replaced in my truck(1952 F-1 stock).It had a lot of play in steering and they found one of the springs was actually broken in drag link and the pitman arm ball was egg shaped?The steering is nice and snug now and truck drives great.Only thing I have noticed is the steering wheel is just a little off center now.Should I just re-center steering wheel or do I need to have a front end alignment?
Old May 4, 2024 | 05:29 PM
moejr's Avatar
moejr
I would pull off the pitman arm, center the steering wheel then reinstall.
Old May 6, 2024 | 10:57 AM
mtflat's Avatar
mtflat
I'm thinking the pitman arm is keyed, but It's been a few years since I had to work on one. You might need to pull the steering wheel to straighten things up.
Old May 6, 2024 | 09:06 PM
leonharu's Avatar
leonharu
The pitman arm is splined not keyed.The steering wheel really is just off center a hair and I just decided to leave well enough alone and drive for awhile.
Old May 7, 2024 | 07:01 AM
Greg Rogers's Avatar
Greg Rogers
You can center wheel using tie rod ends- 1 turn tighter on right- 1 turn looser on left... etc... Then check toe with a tape measure- these trucks were simple...
Old May 8, 2024 | 09:15 AM
AXracer's Avatar
AXracer
Since they were not equipt with PS and were primarily driven slow on poorly improved roads, the steering was set up for that use to make slow steering easier. On today's roads and speeds increasing toe-in 1/16" and adding 2* additional caster shims will make highway driving more stable. May need to add longer headed spring center bolts and/or longer U bolts with shims, rounded head of bolt should fully seat in axle seat recess. Clean out rust and dirt in recess with correct sizes drill bit turned by hand. Be very careful when changing center bolt. Put 2 large C-clamps one on each side of bolt, lay spring on side on floor, stand on spring with both feet while removing/replacing bolt. Spring packs a large force that can suddenly let go while removing known to break ankle if in the way..
Old May 8, 2024 | 09:52 AM
ALBUQ F-1's Avatar
ALBUQ F-1
There are blank splines that have to go in specific orientation; can't rotate it one spline.
Old May 8, 2024 | 09:24 PM
mtflat's Avatar
mtflat
^^^ That's what I meant by keyed.
The steering wheel is also splined.
Old May 10, 2024 | 08:14 AM
leonharu's Avatar
leonharu
Thanks Ross,I did not realize that.So the pitman arm can only go on one way??
Old May 10, 2024 | 08:18 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Looks like it can go on in 4 positions. Probably only one will make sense and isn't a place of adjustment for your issue.
Old May 10, 2024 | 08:39 AM
leonharu's Avatar
leonharu
I have had this truck 45 years and drive everyday.Just had complete brake system and draglink rebuilt.Next project is shifter rebuilt,it is very sloppy.I located a NOS shifter tube.Seems like everything is wearing out now.Thanks Ross for the write up you did on the shifter assembly rebuild which will come in handy!I did get the noisy lifter problem fixed which was on another thread I started.
Old May 10, 2024 | 08:42 AM
moejr's Avatar
moejr
Didn't know the stock pitman arm has blank splines. Leonharu, I apologize for the incorrect information, I have a CPP steering box in my 49 & must have been referring to that.
Old May 11, 2024 | 08:48 PM
Don T's Avatar
Don T
My 51 steering wheel is not indexed to the shaft, it can be rotated a tooth at a time.
Old May 12, 2024 | 06:02 AM
Greg Rogers
I just ordered a repop draglink from Mid Fifty- at 75% off only about 25.00. Just passing along the info.
Old May 12, 2024 | 07:15 AM
leonharu's Avatar
leonharu
Did you get a new pitman arm?Mine was "egg shaped" and the drag link was only half the problem.
