13 code 94 F 150
Old May 1, 2024 | 06:00 PM
kenny nunez's Avatar
kenny nunez
Question 13 code 94 F 150
This denotes a short to ground. Has any one ever located any air bag system shorts to grounds in their truck?
Just wondering if there is a common place to start looking. This truck does not appear to ever been in an accident.
Old May 1, 2024 | 06:13 PM
Mudsport96's Avatar
Mudsport96
Maybe in the column.
Old May 2, 2024 | 04:35 AM
manicmechanic007's Avatar
manicmechanic007
The closksprings are a little expensive
Install an air bag simulator at the base of the column to aid in testing
The simulators are expensive too
Simply unplug the clockspring and see if the code changes to an open circuit code
That to me would signal a clockspring problem
I have the simulators, so to me all of this is futile for someone without all the diagnostic aids
Do the best you can
Have fun.
Old May 2, 2024 | 04:36 AM
manicmechanic007
I would pull the steering wheel off and check the clockspring wiring before getting too far into spending money on parts or sims
Old May 2, 2024 | 10:24 AM
Junktownbill99's Avatar
Junktownbill99
Airbags?
Old May 2, 2024 | 08:49 PM
kenny nunez
13 code
I will pull the steering wheel to check the clock spring. Thanks for the advice.
GreaseGun Joe
Aug 15, 2015 04:52 PM
