02 4.0 Needs Engine
Old Apr 30, 2024 | 11:45 AM
mtnxtreme's Avatar
mtnxtreme
02 4.0 Needs Engine
What year 4.0’s will fit my 02 Ranger ? Need a replacement !
Old Apr 30, 2024 | 07:54 PM
Johnny Paycheck's Avatar
Johnny Paycheck
Any SOHC 4.0 should work. Depending on where you source the engine, accessories may need to be swapped.
Old Apr 30, 2024 | 08:42 PM
85e150's Avatar
85e150
Yours is an OHV, right? Just about any OHV will work, just as any SOHC will work if you have an SOHC.
But don't replace an OHV with an SOHC or vice versa--too many things to change to make it run right.
Get a 4.0, and strip the intake and anything electrical off it. Use the stuff in your truck to replace all that. The idea being that only the mechanical stuff gets swapped and the electronics and control etc all stays the same. Same for OHV and SOHC.
But, there was a change to "better" guides and tensioners somewhere around 2002, so don't get a '98 or '99 SOHC without going through the guides and tensioners.....
Old May 5, 2024 | 03:49 AM
DILLARD000's Avatar
DILLARD000
Best to avoid the early V6~4.0L~SOHC engine short blocks that had a "Rube Goldberg" BalancerShaft;
that was found not to be needed and was deleted from factory engine builds sometime after 2001.
cjfarm11
Mar 23, 2011 11:16 AM
scrapyardking
Oct 27, 2008 11:04 PM
79-400-POWER
Computer Chips & Tuners
Oct 1, 2008 07:05 AM
gnfshn1218
Aug 16, 2003 05:16 PM
barney_44
3.8 & 4.2L V6
Jul 22, 2002 02:54 PM
