75 F-150 horn wiring
Old 04-28-2024, 12:11 PM
John R. Thomas's Avatar
John R. Thomas
John R. Thomas is offline
OLD QUESTION: My Stella is finally home after her long winter's nap. Ref. colored horn wires w/ wire nuts. Does some one live near Waukesha Wi. that would allow me to study
the horn wires under the hood ? The schematics I find are very vague.
Old 04-28-2024, 08:02 PM
1TonBasecamp's Avatar
1TonBasecamp
1TonBasecamp is offline
Can’t help with the visuals up close, cause I’m geographically undesirable for that. 😁😎
But a couple of questions first. Do you have a single, or dual horns? Are they on one side of the engine compartment, or both?
Do you have a horn relay, or not?
Most trucks of the vintage did have a horn relay, but some did not. My 79 does not, due to certain other options.
And I presume you’re having trouble getting the horn to work? Or just wondering what the overall layout is?
Old 04-28-2024, 09:29 PM
John R. Thomas
My 75 does have a horn relay. 3 horns. 2 on driver's side & 1 on the right up by the radiator. What puzzles me are the 2
rubber body plugs. Where do they past through the firewall? What do they connect to ?
Old 04-29-2024, 07:55 AM
beardedcap's Avatar
beardedcap
beardedcap is offline
One of those has to be aftermarket. Do you have some horn button for the third horn that isn't on the horn pad on the wheel? The stock horns buttons are powered through a wire that's part of the turn signal switch harness. BL-Y for the switch. The horn buttons ground through the steering column.
This is the wiring diagram with the horns wiring75_p07.jpg (3864×2544) (fordification.net)
Just get rid of your third horn and throw the extra wiring and **** away.
Old 04-30-2024, 11:25 AM
1TonBasecamp
What puzzles me are the 2 rubber body plugs.
What do they connect to?
Not sure what you’re talking about in this case. Curious though.
Got pictures of these plugs, and what they have to do with the horns?
shakenbake254
01-05-2016 05:48 PM
fisheasy
10-05-2010 07:08 AM
Poison Oil Racing
03-23-2010 01:54 PM
Bikeitswift
1983 - 2012 Ranger & B-Series
04-07-2008 08:21 PM
Quick Reply: 75 F-150 horn wiring
