Help Identifying Part on 7.5/460
Old Apr 27, 2024 | 01:46 PM
just_cody's Avatar
just_cody
4th Gear
Hey there. I noticed the other day that my oil pressure gauge in the dash isn't operating anymore. I began to look into the cause for this, beginning with confirming my oil pressure through the use of a pressure test kit. I'm still searching for the oil sender/sensor on this bad boy but while looking for it, I came across something that peaked my curiosity. I tried to take some good photos of what can be observed on the motor today. I haven't got a clue what this component is, nor do I know if it's reliable just to have sitting unsecured in the hole in the engine I pointed out. Looking to get some insight on what this part is and if this is something that needs to be remedied with a better part/installation. Thank you.
Old Apr 27, 2024 | 11:12 PM
Doosenberry's Avatar
Doosenberry
PCV valve. Looks like the grommet that holds it in the valve cover is in bad shape. You should be able to get a new grommet and have it securely in the valve cover and then you press the PCV valve into the hole in the grommet.
The oil pressure sending unit should be on the top of the block right behind the intake manifold up against the firewall. Behind that double barrel throttle body you have there.
Old Apr 28, 2024 | 10:55 AM
just_cody's Avatar
just_cody
4th Gear
I really appreciate the help. Thanks a lot.
Old Apr 28, 2024 | 03:21 PM
garygnu's Avatar
garygnu
check the pcv valve to see if it is good .
Old May 2, 2024 | 11:31 AM
Brian Ski 44's Avatar
Brian Ski 44
BTW Like Gary said, Replace the PCV while you are there. It is cheap. The grommet should be in the local parts store help section. There are a couple sizes, so take the old one in.
Old May 29, 2024 | 10:50 AM
just_cody's Avatar
just_cody
4th Gear
Got it all fixed up. Appreciate all the help.
robjs111
1978 - 1996 Big Bronco
Nov 30, 2023 11:51 AM
At least it's not a Dodge
Nov 2, 2023 07:25 AM
JoeDaf
Mar 3, 2018 10:46 AM
tbruz
Jul 30, 2015 06:43 PM
FordMuddin'
Oil & Lubrication
Mar 22, 2012 06:13 AM
