A4ld Help!!!!!!!!
Old Nov 25, 2003 | 06:45 PM
kodiak 55's Avatar
kodiak 55
Angry A4ld Help!!!!!!!!
I have a 87 ford bronco II with a a4ld tranny. i put a new front seal in it about 3 weeks ago. i also replaced fuild and filter. here's the problam it kicks in and out of over drive it doesn't slip it's just like it doesn't have the presure to stay in i ajusted the kickdown cable too didn't fix it. 1st 2nd 3rd and revers shift smooth can't even fill it shift but the overdrive kicks in and out drives me nuts i tryed to fix but i just don't know i hope someone can tell me!! thanks any help
Old Nov 25, 2003 | 07:15 PM
chris_p04's Avatar
chris_p04
had same problem
I had the same problem on my old 93 Explorer, it also had the A4LD, and I know exactly what it is, you see the Torque converter is a lock-up torque converter. When the car gets in to the higher milage the seal on the lock-up shaft goes bad, wears out what ever, and this causes it to make a loud thud and go in and out between drive and overdrive. You can either fix it or let it be, if you let it be then eventually, but not for a long, long time, the lock-up feature will stop working but your car would continue to run like it has a regular torque converter.
Old Nov 25, 2003 | 07:36 PM
kodiak 55's Avatar
kodiak 55
thanks were do i get this seal and how do i replace it ???and where's this seal at??
Old Nov 27, 2003 | 11:59 AM
chris_p04's Avatar
chris_p04
The seal is inside the torque converter so you might have to replace the whole torque converter. You can get this at a local dealership. But you might want to talk to the guy's at the dealership because you might be able to just change that seal, I never fixed on mine, I just sold it and got a 94 Explorer. But then again I needed a newer car with less miles.
Old Nov 27, 2003 | 12:39 PM
Opera House Works's Avatar
Opera House Works
Check 3-4 solenoid screen
There is a filter screen on the 3-4 solenoid that cloggs. Check out atcdg.com in tech bull for A4LD. The valve body must be dropped to remove the solenoid keeper in the back. If you don't have a manual, you could get in trouble. There are a couple little plastic hockey pucks under the seperator plate. You will need new gaskets. You can get a manual for $16 at www.bulkpart.com a great filter for $10. Throw that metal screen piece of junk out. A complete gasket seal kit is $29. With this you can change the low/reverse servo seal which leaks at this age.
